10-20-2015, 09:32 AM | #1 |
Belt slip is a reality contrary to claims see the proof
I spent the weekend at Palmer Motorsports park in Ware Massachusetts with my 2013 ZL-1 Auto and burned through 3 tanks of fuel with 11 Sessions over the 2 day event.
With the Trend to add a smaller upper pulley to your ZL-1 which I have always recommended against for obvious reasons, I though it fitting to share this picture after the event. I hear it all the time I don't have any belt slip, I say see the proof. I have an 18% lower with a stock upper and the shortest belt I can run. My Throttle body was spottless before the event and now has a fair amount of belt dust. The moral of the story, Don't fall in the the trap of smaller upper pulleys unless it's your only option. Ted.
www.jannettyracing.com
10-20-2015, 11:14 AM | #2 |
Green HD belt may be a better choice.
10-20-2015, 11:18 AM | #3 |
We run those as well but not available in every size.
I don't believe it will cure belt slip although a tougher belt for sure. Ted.
10-20-2015, 12:00 PM | #4 |
Drives: 2015 ZL1 Join Date: May 2015
Is there a 10 rib option for this?
ERL 434 LSA super block with 6 bolt 1/2" studs
Ported stock blower 2.55/9.55 and NW 102 tb 5" JLT CAI, custom radiator Mamofied TFS heads with 1.8 Y/T rockers and Johnson lifters FI interchiller E85 flex fuel Circle D 3200 Tuned by Speed inc. 755/730 on 93 and 850/822 on corn |
10-20-2015, 12:05 PM | #5 |
Drives: 2013 1SS Join Date: Dec 2012
Is there any way blower rpm could be measured to determine how bad the slippage is?
10-21-2015, 10:13 AM | #6 | |
The point is there is always belt slip, contrary to popular belief. So Lets Not make it worse with smaller pulleys up top. Do all your blower speeds with the lower pulley. Ted.
10-21-2015, 10:20 AM | #7 | |
Drives: 2015 ZL1 Blue Velvet Metallic Join Date: Mar 2015
Will changing the idler pulley help with this or at least provide you the ability to change to one of the Green HD belts mentioned above?
Roto-Fab CAI, ARH LT, SW 3" catback, JRE tune, Elite-2 CC, VMAX TB, Big Gulp, WW II relo, Lingenfelter S/C reservoir
10-21-2015, 12:12 PM | #8 |
I believe the rubber residue is coming from the edges of the belt, and it not necessarily indicative of "slip"
10-21-2015, 01:41 PM | #9 |
Drives: 2011 2SS Convertible Supercharged Join Date: Nov 2010
To me it looks like fly shit. No belt slip. Lol
Sent from my iPhone using Tapatalk |
10-21-2015, 02:28 PM | #10 | |
Drives: Black 2012 ZL1 Join Date: Mar 2013
10-21-2015, 04:39 PM | #11 |
top of the belt also has small grooves in it which could indicate debris between the belt and idler for an instant...
10-21-2015, 06:38 PM | #12 | |
Drives: 2013 ZL1 A6 #7860 Join Date: Apr 2014
Can I go to a 10 rib upper and lower? |
10-21-2015, 07:31 PM | #13 |
Drives: 67RS Camaro ,Black 2013 ZL1 Join Date: Jun 2010
Looks insignificant to me considering the workout it had.
10-22-2015, 09:13 AM | #14 | |||
Max recommended blower rpm is 23000. The closest you can get in 8 rib is 9.17-2.55 combo for 38% or 23,400 LPE does offer a 9.73-2.70 10 rib that is good for 35% or 22,800 which would be your ulimtate solution. My recommendation, try and do everything with a lower pulley unless you have no other choice. Ted.
