03-09-2015, 11:30 AM | #1 | |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
PTM Modes......Misunderstood?
So I've been having fun with my ZL1 since I got her a few months ago. I think one of the most amazing things about this car is the MRC and how it adjust the suspension.
I really think most drivers don't realize what they have at their finger tips... I'm still learning myself. So from what I've read and experience there appears to be 8 modes total: 1. TOUR - Everyday driving. Suspension in "soft" mode for comfortable driving. 2. SPORT - Stiffer suspension. For casual canyon driving. 3. PERF TRACTION 1 – WET / ACTIVE HANDLING ON . Intended for all driver skill levels. . Wet or damp conditions only — not intended for use in heavy rain or standing water. . StabiliTrak is on and engine power is reduced based on conditions. 4. PERF TRACTION 2 – DRY / ACTIVE HANDLING ON . For use by less experienced drivers or while learning a new track. . Dry conditions only. . StabiliTrak is on and engine power is slightly reduced based on conditions. 5. PERF TRACTION 3 – SPORT 1 / ACTIVE HANDLING ON . For use by drivers who are familiar with the track. . Requires more driving skill than mode 2. . Dry conditions only. . StabiliTrak is on and more engine power is available than in mode 2. 6. PERF TRACTION 4 – SPORT 2 / ACTIVE HANDLING OFF . For use by drivers who are familiar with the track. . Requires more driving skill than modes 2 or 3. . Dry conditions only. . StabiliTrak is off and available engine power is available is the same as mode 3. 7. PERF TRACTION 5 – RACE / ACTIVE HANDLING OFF . For use by drivers who are familiar with the track. . Requires more driving skill than in other modes. . Dry conditions only. . StabiliTrak is off and available engine power is available for maximum cornering speed. for Use mode 5 for most consistent performance during drag strip use. When the TCS/StabiliTrak button is pressed again, the vehicle exits PTM mode and the TCS and StabiliTrak systems are on. Use Mode 5 for the most consistent performance during drag strip use. 8. T/C & STABILITRAK OFF Here's the best video I've seen on explaining the driving modes: So which mode do you guys drive in the most?
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
03-09-2015, 11:38 AM | #2 | |
Track > 1/4 Mile
I play around with "tour" and "sport" when I'm just driving around the street. Usually I just keep it in "tour." However the different PTM modes definitely help out. PTM 1 (wet) does actually help when it's raining. I can tell a big difference in PTM 3, 4 & 5 on the track. I usually autocross in PTM 4 or 5, and let me tell you PTM 5 will let you lose it. For actual track days I usually use PTM 3, especially if I'm not familiar with the track. once I get more familiar I'll play with 4. The PTM on the track in 3 or 4 is very cool, it will regulate just the right amount of power to make sure you have maximum traction in turns. Here's one of my videos from a track day and you can hear in some turns the exhaust kicking in and out (for example 0:17-0:20) that is the ECU feathering power to maximize grip through the turns.
03-09-2015, 12:01 PM | #3 | ||
KaBoom1701
I used PTM mode #3 at Streets of Willow CW last time out and I found it to be too restrictive around the corners....almost as if it was cutting power or torque....made it hard to have a fast corner exit speed. It was my first time out on the track with the ZL1 so I didn't want to due something stupid. I just left it on PTM #3 but I think next time I'll move up to PTM #4 and she how the car handles.
Mods:
03-09-2015, 12:05 PM | #4 |
Maybe I should mess around with the PTMs.
From my Z to my modded SS, everytime I start the car I hold down the buttons and turn of everything off.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4) SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129 SOLD-2011 SS M6: Blower, Cam, Alky, LTs. |
03-09-2015, 12:10 PM | #5 |
Drives: 2012 M6 ZL1. 2019 Altima.07 FJR1300 Join Date: Nov 2011
I'm in sport mode probably 75% of the time..
03-09-2015, 02:20 PM | #6 | |
Drives: '12 ZL1 #1609 Join Date: Feb 2010
Life is too short to drive cars that suck.
My build Thread |
03-09-2015, 02:33 PM | #7 |
Great topic...99% of the time Im in tour mode without any PTM selected.
But I have a question I've wanted to ask regarding this for a while. In watching one of the videos in the sticky, the PTM mode will reduce torque & horsepower depending on which mode is selected. So the question (if I can word it right) is; does the ZL1 have all available horsepower and torque available when none of the PTMs are selected? Or is all horsepower and torque only available in PTM5 (#7 in KaBooms list)? Thanks... |
03-09-2015, 03:16 PM | #8 | |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
03-09-2015, 03:35 PM | #9 |
1st Civ. Div.
Drives: Camaroless for now...RIP "Big SexZ" Join Date: Dec 2007
With all the nannies turned off you have no intervening controls reducing power with regards to steering angle, traction, and yaw rate.
I usually run in PTM 3 on the street unless the wife is riding or the road is rough then its PTM 2 and on wet and rainy days I like PTM 1.
Swift....Silent....Deadly
03-09-2015, 03:43 PM | #10 |
Drives: '13 Silver Ice Metallic ZL1 Join Date: Jul 2012
I drive in Sport mode all the time. In the occasions that I used PTM3 and/or 4, I felt like that car didn't have as much torque.
03-09-2015, 04:00 PM | #11 |
Drives: 2014 ZL1 Join Date: Jan 2015
Great thread
03-09-2015, 04:04 PM | #12 | |
KaBoom1701
This was phase 2 of this topic. It would be interested to know what PTM3 vs. TPM4 does when it comes to reducing engine HP or Torq. Even if we knew the % of HP or Torq. reduction it think it we be good to know. Anyone here have any Chevy Camaro engineers connections?
Mods:
03-09-2015, 07:30 PM | #13 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
I use PTM 5 a lot because I like the tighter steering.
03-09-2015, 07:49 PM | #14 |
Drives: 2017 ZL1 M6 Join Date: Jul 2010
I usually keep the car on PTM 5. Never know when I will need it.
2017 Nightfall Gray Metallic ZL1 M6
2014 Black GMC Serria Z71 1996 Red Z28 |
