Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
Old 08-11-2014, 04:17 PM   #1
htoniv
Drives: Camaro
Power Steering Issue
Hello all,
it seems my power steering fluid from my left side has a leak. Found this when i was doing my oil change just the other day.
My steering has been acting weird, i noticed it is more rubbery/squeaky.
Should i use the stop leak liquid into the power steering fluid
if not
I am wondering if anyone knows if this is covered in the power train warranty?
Not sure if this is posted in the correct session, but any help would be appreciated
Thank You
htoniv is offline   Reply With Quote
Old 08-12-2014, 08:00 AM   #2
htoniv
Drives: Camaro
bump, any takers lol
Old 08-12-2014, 01:18 PM   #3
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
IMHO any "stop leak" solution is a bad idea unless you're in the middle of no-where with the intention of replacing the component (radiator, pump,etc...) as soon as you get to civilization.
How many miles are on the car? I'm not sure, but I doubt this is covered under the power train warranty. Did you purchase from a dealer?
I think you're best shot is to go to your local dealer and hope for the best.
Ventmaster is offline   Reply With Quote
Old 08-12-2014, 04:46 PM   #4
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Is it coming from the pump or the O ring?
Sikoriko is offline   Reply With Quote
Old 08-12-2014, 07:30 PM   #5
htoniv
Drives: Camaro
It is coming from the bottom piece near the wheels =\
nearly 70k on the car.
Old 08-12-2014, 07:50 PM   #6
phenix34
phenix34's Avatar
Drives: 2011 1LT Silver Camaro
i just had mine replaced today but i have 27,000 miles on mine.
phenix34 is offline   Reply With Quote
Old 08-13-2014, 09:41 AM   #7
htoniv
Drives: Camaro
what did you replace?
Old 08-13-2014, 12:55 PM   #8
backbaconrules
backbaconrules's Avatar
Drives: 2011 LT Black
I had issues with my power steering this winter. There have seen return hose issues in extreme cold conditions before and fixed mine no problem. Could yours be cracked enough to just leak? Long shot though seeing it's under pressure.
backbaconrules is offline   Reply With Quote
Old 08-13-2014, 01:11 PM   #9
htoniv
Drives: Camaro
Did they replace that under your power train warranty mate?
Old 08-13-2014, 01:26 PM   #10
backbaconrules
It was still under warranty.
