Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro Photos | Spyshots | Video | Media Gallery
Old 07-11-2014, 09:24 AM   #1
A_DILLA
Optimus Prime
A_DILLA's Avatar
Drives: Camaro ZLS [COTW 09/22/14]
Arrow door panels painted white (Please help out)
And I wanted to ask why I needed different size screws to do the install? Here's a pic of the panels and a pic of what screws I saw on a DIY says I need. Please correct me if I'm wrong.
A_DILLA is offline   Reply With Quote
Old 07-11-2014, 09:55 AM   #2
justjoshin
justjoshin's Avatar
Drives: 2010 SW 1SS L99 Camaro
no anawers to help you out, but I do have a question for you...lol. Where these panels covered with the cloth prior?
justjoshin is offline   Reply With Quote
Old 07-11-2014, 10:22 AM   #3
A_DILLA
Optimus Prime
A_DILLA's Avatar
Lol thx man, no in the 1st picture you can see they came painted from GM but just 2 different colors so i had them painted summit white.
Old 07-11-2014, 12:45 PM   #4
justjoshin
justjoshin's Avatar
I think I found the answer for you:
Old 07-11-2014, 03:51 PM   #5
Gibroni
Drives: '12 IOM LT 'vert
I can't wait to see the pics of these installed. Should have covered them in white leather.
Gibroni is offline   Reply With Quote
Old 07-11-2014, 04:51 PM   #6
A_DILLA
Optimus Prime
A_DILLA's Avatar
Ok so I need to buy 13 8mm screws from homedepot?
Old 07-11-2014, 05:03 PM   #7
justjoshin
justjoshin's Avatar
13 for each panel, so 26.
Old 07-11-2014, 05:09 PM   #8
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
I went to Lowes and picked up bag of #8 & #10 screws and a box of tiny washers. One by one i installed them using washers as standoffs to ensure there was no way they could poke through the inside. As i did each one i held my finger over the area so i could feel if it began to slightly push forward. If it did i backed up and added another washer or two and repeated. Each panel is now rock solid tight.
I did this more than 3 years ago and they are still perfect today.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 07-11-2014, 05:29 PM   #9
A_DILLA
Optimus Prime
A_DILLA's Avatar
#8 and #10 are different screw sizes right? I Think I'm good With Just The 8mm right?
Old 07-11-2014, 05:30 PM   #10
A_DILLA
Optimus Prime
A_DILLA's Avatar
Anybody got a picture of where to splice for power? I hear. The door lock is it?
Old 07-11-2014, 09:24 PM   #11
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Yes they are different sizes. The reason is i found the 8 just BARELY grabbed enough on a few so i had to go with the 10's. I am sure i did it overkill style but, i wanted to make sure i only had to do it once and that i would not ever have any rattles or anything. I am positive a couple of them if i had used 8's would have fallen out by now.
Old 07-12-2014, 03:26 AM   #12
A_DILLA
Optimus Prime
A_DILLA's Avatar
Gotcha
Old 07-13-2014, 02:55 PM   #13
A_DILLA
Optimus Prime
A_DILLA's Avatar
Arrow
So i installed the door panels but I came across a problem, I can't see the ABL lights thru the door panels, there is like no gap what so ever. . Do you guys think I installed them wrong or is it because I have a 2013 2Ls and the door panels are different? Please help me out. .
And does anyone have a clear picture where I can tap the positive and negative. There is a factory plug tucked behind the door and ABL pigtail plugs on but I didn't push all the way and the light doesn't turn on either. Here are some pictures. I'm about 85% happy with the results but I would love to be 100% happy with the ABL lights turning on and showing thru the door panels.
Old 07-13-2014, 06:58 PM   #14
RolltideSS
RolltideSS's Avatar
Drives: 2018 SS 1LE
Who did you buy the panels from? If they are the GM OEM white ones then the ABM is pre-setup and if you lights are working the whole door panel will glow blue in addition to having the intense beam across the top of the panel (really cool look at night). If you bought them from a place like RPI you would have had to tell them so they didn't paint over the spot for the ABM. I would think if your light were working It would still cause the panel to glow though.
RolltideSS is offline   Reply With Quote
