Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 04-19-2014, 08:53 PM   #1
cam99
cam99's Avatar
Drives: 2012 ZL1
10 seconds on 10PSI?
Has it been done with bolt on's? not sure. Can it be done? I'm trying to see if I can. Spent all last year shooting for it and came very very close many times but car made 11.0 passes at 127-128 several times on different occasions, but 10's have eluded me. I run at a PA track so DA is always a problem. I realize if I went to atco or some negitive da track it would probably get me there, but I want it to be at my track. I want to do it with the power mods I currently have. which means no more boost, stock manifolds, stock stall converter, and stock injectors. I've tried to remove weight wherever I can ( rear seat out when racing, corbeau front seats, leightweight crashbars,braile battery, dr's on racestar wheels) but I'm looking at a few more items to get there. I will be stoked if I can get it there
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
on hoosier drs and skinnies
@ PRP with 1100DA
cam99 is offline   Reply With Quote
Old 04-19-2014, 09:01 PM   #2
Bigtime53
Bigtime53's Avatar
Drives: 2013 ZL1
What are your 60 ft times?
Bigtime53 is offline   Reply With Quote
Old 04-19-2014, 09:02 PM   #3
cam99
cam99's Avatar
Drives: 2012 ZL1
1.59-1.61 like clockwork
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
@ PRP with 1100DA
Old 04-19-2014, 10:27 PM   #4
Bigtime53
Bigtime53's Avatar
Drives: 2013 ZL1
Maybe a set of headers and get high perf cats or run no cats. 60ft times are good. I think you will get there soon though. Good luck!
Old 04-19-2014, 10:28 PM   #5
Bigtime53
Bigtime53's Avatar
Drives: 2013 ZL1
Just re-read your sig,I see you are not running cats. Get headers!
Old 04-20-2014, 04:22 AM   #6
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
11.04@124 was my best full weight with 93 octane. No skinnies, Z06 replica rears, stock injectors, stock exhaust with cats & stock manifolds, stock injectors. My only mods were 9.55 lower(not 10%), 90mm LS3 throttle body(unported), tune, ADM race CAI & drag radials. Stock HX with no reservoir too. The runs were at MIR and I ran it 14 times that day. 60' was always in the 1.60 range. It seems like when restrictions in the exhaust are lessened by headers or removing cats, you must spin the blower faster to compensate. Just for fun, I ran my car at the track recently with an 8.66 lower only which is my road course pulley. It still managed 11.40@121 with a 1.67 60'. The DA was approx +1500ft. You can do it, Cam...but spin the blower a little faster and you will crush 11.0 with ease.
Old 04-20-2014, 08:17 PM   #7
cam99
cam99's Avatar
Drives: 2012 ZL1
I will at some point upgrade power further, but I really want to hit that number at the power level I'm at now just to prove it can be done. It's a challenge. I did slap an 18% pulley on it once with a splash of race gas, but the tune wasn't happy with the extra boost, and or octane, and popped me into limp mode a couple times. So swapped back to 10% and been there since. It didn't et any better (worse actually), in fact the 60 dropped a little, but did trap over 130 on that pulley.
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
@ PRP with 1100DA
Old 04-20-2014, 09:34 PM   #8
nasa.zl1
Drives: 2011 White Camaro
If you simply want to hit that mark with what you got without more modsand you are that close then try a different track.
1969 ZL1 Camaro, "I'll be back"
nasa.zl1 is offline   Reply With Quote
Old 04-20-2014, 10:52 PM   #9
hognutz
hognutz's Avatar
Drives: 2013 ZL1
your so close obvioulsy with the right DA you could do it. you might consider one more mod. headers or ported snout (or both ha ha) something like that to get you in the consitantly in the 10.9X.
shopping for 2017+1le or zl1
2009 CTS-V -sold
2015 Hellcat-sold
2013 ZL1 -sold
2007 Z06- sold
2014 Chrysler 300
2011 Duramax 8" lift, deleted tuned
hognutz is offline   Reply With Quote
Old 04-21-2014, 05:56 PM   #10
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
Take the passenger seat out, it weighs like 80 pounds.... You will be there with the mods you have. Or like Stephen says, spin the blower more and get a tune to match.....
I don't know that anyone has done a 10 with only 10 pounds of boost but it is not something that most people measure. Boost in itself is not a good judge of anything. If you have an efficient cam and heads and a set of headers you will spin your blower at the same speed as a stock car but make 4 pounds less boost. Boost measures the restriction of a motor as much as it measures the drive of the supercharger. I think if I had an auto transmission my 427 with trickflow heads, a radical custom cam, headers and 2.3 liter LS9 blower could run in the 10's with only 10 pounds of boost. I'm certain it could with nitrous. Nitrous doesn't add much boost but gives me over 350+ whp.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 04-21-2014, 06:22 PM   #11
cam99
cam99's Avatar
Drives: 2012 ZL1
Well I am planning on hitting the track thursday and mounted up the drag wheels. I finally bought rear racestars to match the fronts this winter. They are sadly a little heavier than the corvette wheels I was running, lol, so that's not going to help. However what might help is I just ordered a set of m&h front runner tires to replace the falken radials that are currently on the fronts. They are heavy as all hell at 28# each and the m&h are listed at 5# each, so I can be looking at ditching around 40# of rotational weight if that's correct
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
@ PRP with 1100DA
Old 04-22-2014, 10:50 AM   #12
jessrayo
Speed Freak
jessrayo's Avatar
Good luck and let us know how it goes.
Old 04-22-2014, 03:34 PM   #13
cam99
cam99's Avatar
Drives: 2012 ZL1
will do. M&H's showed up today, so they are mounted up. Hoping for halfway decent DA
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
@ PRP with 1100DA
Old 04-22-2014, 08:22 PM   #14
Stephen12ZL1
Drives: '21 ZLE A10
M&H drag raidals are super sticky and dead hook at 16-18psi on a well prepped track
