Old 04-27-2018, 04:56 PM   #57
vincentcamaro
Drives: Camaro SS 2013
I just wish someone can tell me if I can turn my SS into a 1000HP car using only GM/Chevy performance parts including the LSX454R Engine.
vincentcamaro is offline   Reply With Quote
Old 04-28-2018, 12:43 AM   #58
blake-b
blake-b's Avatar
Drives: 2009 ZR1
With enough money, anything is possible. Put the LSX454R in your car with a 200-300 shot of nitrous and it will be a 1000hp car. However, you're going to need to mount coils/ignition system as you'll see there are no coils on it. You're going to have to swap EFI onto it or make the carburetor work in your car. Carburetors are a step backwards in technology in my opinion if you are putting one into a modern car that is anything other than a race car. I'd put an LSX454R in my 69 camaro but not my 2010.
Would I use the LSX454R? No, I would not. For the amount of money it costs, a stronger engine can be built. Also, it has 13.1:1 compression. You're going to need a lot of octane to keep it from pinging (detonation). Unless you know a place that sells C16 at the pump at God knows what per gallon, pump gas won't work.
My camaro can make as much ~1200whp and is docile enough to be a daily driver except it gets horrible gas mileage and uses E85. There is only one station around me that sells it. I think I can get 110 miles or so out of tank of gas.
Get a hold of some engine shops and get some quotes. You can have an LS 454 built but it won't be all with GM/Chevy parts. The rods, crank, pistons, cam, bearings and other parts will all be aftermarket. The block, heads, covers, and intake could all be GM/Chevy.
Old 04-28-2018, 12:10 PM   #59
vincentcamaro
So say I buy the engine from the Chevy website. And I take my car and the engine to my local dealership and can they install it for me and recommend everything necessary
Old 04-28-2018, 07:50 PM   #60
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Yes but I'd be surprised if the dealership would do it. I would not trust most dealerships with that kind of work. A speed shop is a better choice. There are many good ones out there.
Old 04-28-2018, 11:20 PM   #61
vincentcamaro
How can I find a reliable legit one in my area
Old 04-28-2018, 11:27 PM   #62
blake-b
blake-b's Avatar
Drives: 2009 ZR1
It doesn't have to be in your area. You can ship your car anywhere you want. There are many, many reputable shops around the US.
I am not familiar with shops in your area but I'd ask in the California forum on here and on LS1tech. You can also Google around and see. Go to some shows, etc and ask around. The bad thing about the internet is when people are happy, they say nothing. If something goes wrong, they spread it like wildfire. If you find a local shop, stop by for a visit before you make any arrangements to take your car there just to see what it is like.
If you want to PM, I'll give you the names of specific shops I would suggest you contact.
Old 11-28-2018, 09:33 PM   #63
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Here is my build..
- •AFR Mongoose Heads Upgraded Exhaust Valve to Inconel
- •Callie’s Dragon Slayer Crank APH31T-DS58
- •Callie’s Ultra H beam Rods #U16300
- •Weisco pistons #10-K398X7
- •Weisco Piston wrist pin #10-S718
- •Johnson Lifters 2110R
- •ARP Main Studs 234-5608
- •ARP Head Studs 234-4317
- •LS9 Head Gasket 12622033
- •Clevite Main Bearing set #171-MS-2199H
- •Clevite Rod Bearings #171-CB663P
- •ACDELCO Header Gaskets #12617944
- •Rear Main Seal #89060436
- •Rear Main Cover Gasket #12639249
- •Water pump With Gaskets #257-734
- •Timing cover gasket #12633904
- •Oil Pan Gasket 12612350
- •Front engine cover seal #296-02
Nighthawk89 is offline   Reply With Quote
Old 02-25-2019, 05:32 PM   #64
Kleinarms
Drives: 2013 2SS 6 spdBorla attack, CAI,LTH
Just thought I would chime in here. Like many people I would love to build my car up like you guys here with the big builds. Realistically not going to happen. Yeah 1000hp sounds cool. Hell anything over 500 is very cool. for that matter our car bone stock are pretty damn awesome, that's why we love them! As I understand it once you get above a certain Hp/Trq, you start to need other parts. Right now my 2013 2SS 6spd has borla attack exhaust, CAI, And soon LTH with a good dyno tune. After that maybe gears and a cam? can stock components handle a supercharger? Can I get over 500rwhp with mostly stock components?
Just throwing this out there.
Kleinarms is offline   Reply With Quote
Old 02-25-2019, 09:06 PM   #65
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Send a message via AIM to SSE 4 2SS Send a message via Yahoo to SSE 4 2SS
I'll place a disclaimer here before I comment.... You can break parts at stock power.... you can break parts with bolt ons, and you can most assuredly break parts with power adders.... The flip side is there are lots of guys running around with completely stock bottom ends and heads, clutches transmissions and differentials making well over 500 RWHP....
The vast majority of it is in the tune, and then in driving styles...
Now.... A close friend has a SBE (stock bottom end) 2SS making 458 RWHP, 548 RWT, and has run 10.16. He has headers and a cam..... He is now up to 489 RWHP.... No power adders.... Turbo 400, Rear gears if memory serves.... and he has lightened the car a bit....
There are guys running just a bolt on blower kit from Maggie making 460-520 or more...
There are folks making a bit more with KB and Whipple kits.... in the mid 500's and up to mid 600's
I'm sure there are more but these are the general numbers I remember...
Then you get into Turbo kits....My personal favorite...
There are turbo kit cars making well north of 600 RWHP with nothing but a bolt on turbo kit and a tune... There are others making north of 700 and 800 and 900 and a few have been over 1K. I wouldn't push it to that level, but it has been done....
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
“If everything seems under control, you're just not going fast enough.” Mario Andretti
If you can turn, you ain't going fast enough...
SSE 4 2SS is offline   Reply With Quote
Old 02-25-2019, 09:32 PM   #66
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
Heh, your only making 2500 RWHP ;o)
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari
See My Build: http://www.camaro5.com/forums/showthread.php?t=385577
hammdo is offline   Reply With Quote
Old 03-17-2019, 09:05 PM   #67
schul274
Drives: 2011 Camaro SS2RS, 1970 Camaro SS
Engine:
Block - LY6 - bored 0.065 over (6.2l)
CI? - 376
Crankshaft - lsx376-b15 forged crank
Rods - lsx376-b15 forged rods
Pistons - lsx376-b15 forged pistons
Rings - lsx376-b15 rings
Heads - 823s, hand ported by me (i do not know what i am doing)
Valves/Springs - BTR
Cam - BTR stage 2 turbo cam
Timing Chain - stock
Oil pump - melling
Aftermarket Dampner - underdrive (id have to look up the brand)
Anything else - ebay special sheetmetal intake
Blower/Turbo:
Type - On3 single 88mm turbo
Modifications - 11lb spring. maxed out the turbo at 18.5 lbs w/ manual boost controller
Fuel:
Pump - fore performance (not innovations) triple pump
Injectors - FIC 127s
Meth - no
etc - flex fuel sensor/e85, -10 feed, dual fed, aeromotive regulator, return style
Exhaust:
Headers - on3 turbo kit
Cats or No Cats - its a hood dump
Cat back - also, hood dump
Cut outs - you could call it that
see more at my build page:
https://www.camaro5.com/forums/showthread.php?t=536290
schul274 is offline   Reply With Quote
Old 06-12-2019, 05:19 AM   #68
jamieereynoldss
Drives: ZL1 1LE
The most important things in the car are motor, chassis, body fashion, safety and cool car nameplate.
jamieereynoldss is offline   Reply With Quote
