Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
Old 05-12-2012, 12:35 AM   #1
jnikkila
jnikkila's Avatar
Drives: LS/LLT
4pack gause cluster
Has anyone seen these for less? This seems a bit steep for what it is...
http://www.phastekperformance.com/GM...s-92247189.htm
jnikkila is offline   Reply With Quote
Old 05-12-2012, 01:33 AM   #2
TreasureCoastCamaro
CRUISN1
TreasureCoastCamaro's Avatar
Drives: 2010 LT/RS
Ya.... www.gmpartshouse.com $299.00 complete "plug & play"
2010 Camaro 1LT/RS, 6 Speed, RX Catch Can w/ Breather, CAI, DRL Harness, V-LEDS, 4 Gauge Cluster, Painted Calipers, RS Emroidered Headrest. Build #05410
TreasureCoastCamaro is offline   Reply With Quote
Old 05-12-2012, 01:40 AM   #3
BDH
Drives: 2012 1LT-RS
Here's the C5 thread. I installed them couple weeks ago. Love the look!
http://www.camaro5.com/forums/showthread.php?t=148200
BDH is offline   Reply With Quote
Old 05-12-2012, 11:11 AM   #4
bmorecam
Drives: jealous vendors mad!! HAHA!!
I would never get those gauges unless you just want it for looks. Can you actually see down that far while driving anyway? LOL
All turbo, supercharger, tuned, modded guys need this, plain and simple! I said this a million and one times already.
bmorecam is offline   Reply With Quote
Old 05-12-2012, 07:24 PM   #5
jnikkila
jnikkila's Avatar
Drives: LS/LLT
thanks gentlemen!
and bmore I was actually considering that route considering you can have more information displayed and honestly it looks cooler anyway. My biggest concern now is oil temp/pressure because I don't know the people that are servicing my car very well...i would do all work myself but two years of dealer maintenance service was part of my signing agreement.
Old 05-13-2012, 09:43 PM   #6
bmorecam
aeroforce can display oil pressure more accurately digitally. Can you actually see where that fat needle is really at LOL.
These are just part of PID's you can monitor with aeroforce.
RPM
MPH
Intake Air Temperature
Mass Air Flow Sensor Frequency
Mass Air Flow Sensor (lb/min.)
Engine Coolant Temperature
Injector Pulse Width (bank 1 and 2 if supported)
Long Term Fuel Trim (bank 1 and 2 if supported)
Short Term Fuel Trim (bank 1 and 2 if supported)
O2 Sensor Voltage (bank 1 and 2 if supported)
Fuel Pressure (direct injection)
Manifold Pressure in PSI (Boost pressure for factory
turbo/supercharger applications)
Ignition Advance
Knock Retard
Engine Run Time
Misfire information
Commanded AFR
Commanded Lambda
Commanded EQ
Battery Voltage
Transmission Temperature
Transmission slip speed
Transmission torque send
Transmission torque commanded
Remaining fuel
Throttle Position Percentage
Throttle Position Voltage
Oil temperature
Oil pressure
Fuel economy (vehicle must have a MAF
Horsepower sensor for these 2 items)
Two user configurable analog inputs 0-5v (you can actually purchase a seperate bosch wideband sensor and display real time AFR right from the gauge, I would do 1 for bank 1 to display on aeroforce gauge and another for bank 2 such as AEM uego or any other wideband gauge)
Fueling status (open or closed loop)
and many more..
The best gauge ever with shift light! I sound like a sale's guy LOL Can I get commission aeroforce??
Old 05-13-2012, 10:34 PM   #7
butters
butters's Avatar
Drives: 2010 2SS/RS L99
Wow, great find!
Where did you get your gauge pod from?
butters is offline   Reply With Quote
