TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
Old 04-14-2012, 04:02 AM   #1
MACE_ENG
MACE_ENG's Avatar
Drives: LLT Machine
Thumbs up Plenum Spacer for your LLT
Yes more stuff for the LLT
Been a while coming but had been bogged down mainly with some legalities about product protection in general. All good though
Key benefits:
* Provides better air distribution between cylinders, resulting in more power
* Produces a cooler intake manifold charge resulting in more power.
* Improvement in low end torque by increasing plenum volume
* Better fuel economy
* Reusable over and over again.
* No undesirable side effects
What is a plenum spacers and what does it do?
A Plenum spacer is a special spacer that sits between your plenum cover and intake manifold. Its main purpose is to improve air distribution between cylinders by slowing down the air speed inside the plenum chamber. As a result there is less of a pressure drop inside the plenum chamber between cylinders, and less air momentum, resulting in better air distribution and power. The change in airflow characteristics is shown in the diagram below.
Not only will our spacer help you make more power, it will also help prevent any costly rebuilds through dangerous lean outs that may occur in high horsepower/boost applications (due to poor air distributions).
In addition to improving air distribution between cylinders, the increase in plenum volume also increases low down torque.
Made from the same thermal resistant composite material as our manifold insulators, means that further horsepower gains are to be had due to the reduction in air temperature
What's Included?
Plenum spacer, longer plenum screws, and gasket maker. Basically everything you need for the installation
What about installation?
Installation is straight forward, requiring only the removal of your plenum cover to install the plenum spacer.
MACE_ENG is offline   Reply With Quote
Old 04-14-2012, 04:10 AM   #2
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
So...... When are they available and pm me price please
Click Picture for Build Thread
lscamaro is offline   Reply With Quote
Old 04-14-2012, 04:19 AM   #3
MACE_ENG
MACE_ENG's Avatar
Drives: LLT Machine
Pics of the spacer and where it goes (on the engine of course LOL)
I'm hoping bmorecam will be able to chime in here with pics of it installed
The bolts that will come with the kit will be the ones around the plenum and not the inlet manifold as such. The reason for this is that it's difficult to have different length bolts to support various insulators on the market.
In saying this though we will have a bolt pack to suit our insulators eventually.
PLEASE be mindful of this fact before ordering, as there may be additional costs associated with sourcing specific fasteners.
Old 04-14-2012, 04:24 AM   #4
MACE_ENG
MACE_ENG's Avatar
Drives: LLT Machine
Now
You have a PM
Old 04-14-2012, 04:58 AM   #5
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
So you're expecting addional improvements- even with the 25mm spacer already in place?
Also, I thought maintaining momentum of the airflow was nececessary for optimal performance .
Thanks-
Ventmaster is offline   Reply With Quote
Old 04-14-2012, 05:16 AM   #6
MACE_ENG
MACE_ENG's Avatar
Drives: LLT Machine
Thanks-
It depends where, in this context no
Old 04-14-2012, 05:28 AM   #7
Ventmaster
Ventmaster's Avatar
O.K. I can accept that, but do I want a plenum spacer in addition to my 25mm insulator/spacer?
Old 04-14-2012, 05:40 AM   #8
MACE_ENG
MACE_ENG's Avatar
Drives: LLT Machine
It was designed to be compatible with the 25mm item
bmorecam is happy with it, in conjunction with his 25mm insulator, and if his happy I'm happy LOL
It will definitely complement the LLT manifold, just in a different way to that of the insulator (with or without the insulator). In saying this though for people who don't have either I would recommend going the insulator first or both at the same time (if budget permits of course)
What we've specifically done to make fitment easier is to give people options with omitting the installation of the rearmost plenum bolt, by increasing material thickness across that area
Have also subjected this to FEA testing so she'll comfortably take 40psi of boost. Just need to find someone game LOL
Old 04-14-2012, 06:07 AM   #9
mhog
mhog's Avatar
Drives: 2010 V6 Camaro 2LT/RS
I want. Pm me please!
mhog is offline   Reply With Quote
Old 04-14-2012, 06:11 AM   #10
Ventmaster
Ventmaster's Avatar
Well I need an excuse to take the IM off and smooth a few transitions between it and my insulator (now that I know it can be sanded-right?).
This will give me a reason to pull it back off!!
Old 04-14-2012, 06:21 AM   #11
MACE_ENG
MACE_ENG's Avatar
Drives: LLT Machine
Done
It can definitely be easily sanded
It would also be a good time to cleanup/port the manifold a little in some areas. There are some pics floating around to be able to so from memory.
Old 04-14-2012, 07:35 AM   #12
mydreamcar
My Dream Car
mydreamcar's Avatar
Drives: 2011 SIM LS3 1SS
would this still work well if you bought the Icelotor from tracy(RX). if so pm me a price
CAI intake/ADM Scoop/Stainless Power Headers/Dynatech cat back exhaust/Vitesse Throttle Control/ Ported Throttle Body/QTP Electric Cutouts/ 3.91 gears and janetty rear posi/ Tuned by Janetty racing
mydreamcar is offline   Reply With Quote
Old 04-14-2012, 07:41 AM   #13
ChadG
ChadG's Avatar
Drives: 2010 Black Camaro LS
Damn you Bmore!!! You always get the good stuff first!!!
Just kidding! Looking forward to hearing more about this product and its performance and ease of installation combined with other insulators.
ChadG is offline   Reply With Quote
Old 04-14-2012, 08:08 AM   #14
CamaroV6
Drives: Camaro V6 1LT Manual
I want in please pm when available and Price!!!!
CamaroV6 is offline   Reply With Quote
Join TEAM LLT social group RSokie Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 2849 02-10-2014 09:41 PM
MACE 25mm Manifold spacer/ insulator to suit LLT MACE_ENG V6 Bolt-Ons & Tunes 50 07-16-2012 12:39 AM
Vmax Intake Manifold "BLACK ICE-olator" V6 LLT Base Test Results Mike Norris Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 297 03-31-2012 07:41 PM
Throttle Body Spacer on LLT Nutbutt Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 19 11-14-2011 11:02 PM
