Old 02-09-2012, 01:38 PM   #1
gl2filmerguy
gl2filmerguy's Avatar
Drives: 2010 Summit White Camaro SS/RS
Pins and Bolts for Brembo Brakes
I just got my calipers powder coated, and I was wondering where to buy the new pins and bolts to install the calipers back on.
Thanks!
gl2filmerguy is offline   Reply With Quote
Old 02-09-2012, 01:53 PM   #2
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
Here's a list of Brembo parts for the SS. For what the pins cost, might want to check a dealer since shipping will likely offset any savings. I haven't checked in a while so not 100% for sure on price.
Brembo Caliper Parts
92233189 Driver side front brake caliper. Without pads
92233188 Passenger side front disc brake caliper. Without pads.
92233177 Driver side rear disc brake caliper. Without pads.
92233176 Passenger side rear disc brake pad. Without pads
11570788 Front disc brake caliper bolts; to knuckle. 4 per vehicle. OPTIONAL
89047711 Front disc brake pad pin kit; 2 per vehicle.
89047728 Rear disc brake pad pin kit; 2 per vehicle.
11515781 Front disc brake caliper bolts; to knuckle. 4 per vehicle. OPTIONAL
92227529 Driver side rear brake backing plate. OPTIONAL
92227530 Passenger side rear brake backing plate. OPTIONAL
bannonm is offline   Reply With Quote
Old 08-21-2016, 06:24 PM   #3
OmniCamaro
US Veteran
OmniCamaro's Avatar
Drives: 2011 Silver Ice Metallic 2SS/RS A6
Excellent post bannonm! Thank you!
Yes I know this is old but it's good info!
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS)
OmniCamaro is offline   Reply With Quote
Old 08-21-2016, 09:40 PM   #4
Tajefe Couple
Tajefe Couple's Avatar
Drives: Never just fly under the radar
Attached are complete instructions for a conversion. Below are all P/N's needed for the kit. Basically what bannonm listed. Got my parts here https://www.gmpartsnow.com/auto-parts
22956541 Master Brake Cylinder 1
23131778 RR Brake Shield 1
23131777 LR Brake Shield 1
92229712 Front Hose 1
92229713 Front Hose 1
92229716 Rear Hose 2
21012386 Front and Rear Hose Washers 8
11569590 Front and Rear Hose Bolts 4
11611687 Rear Drive Shaft Nut 2
22907156 SPO Front Service Pad Kit 1
89047711 SPO Front Caliper Pin Kit 2
92233176 RR SS Caliper 1
92233177 LR SS Caliper 1
92244287 LF SS Caliper 1
92244288 RF SS Caliper 1
92245928 Front Rotor 2
92245929 Rear Rotor 2
89047228 Rear Caliper Pin Kit 2
89047744 Rear Pad Kit 1
22942442 Chevrolet Performance Badge 1
11515781 Rear Caliper to Knuckle Bolt 4
11570788 Front Caliper to Knuckle Bolt 4
File Type: pdf ss-brake-kit-for-v6-camaro-specifications-23120542.pdf (2.36 MB, 181 views)
Old Skool
Tajefe Couple is offline   Reply With Quote
Old 08-21-2016, 10:38 PM   #5
ddo_texas
Drives: 2014 Camaro v6 Convertible RS
Just ordered 4 front bolts on amazon for less than $30 free shipping. they also had pins and clips don't remember the cost.
ddo_texas is offline   Reply With Quote
Old 08-02-2017, 09:24 AM   #6
toehead93
Drives: 2014 2SS/1LE
Anyone know how to convert these to AC Delco part numbers? I need to find the rear pint kit 89047228.
Used Racing Brake 2 Peice Rotors for sale:
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 08-02-2017, 10:15 AM   #7
Synner
Drives: cars
Go to the AC Delco website and put in vehicle info.
Synner is offline   Reply With Quote
5th Gen Suspension -- The Book JusticePete Suspension / Brakes / Chassis 151 05-07-2015 05:52 PM
08 G8 GXP Silver Brembo brakes (2010 Camaro) redjeff Suspension / Chassis / Brakes 7 06-26-2011 09:11 PM
