Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 04-22-2024, 10:58 PM   #365
Hulk
Hulk's Avatar
Drives: 2011 Synenergy Green 2SS/RS
Originally Posted by 1JEWLDSSRS View Post
When I had the MRR M228's on my Camaro, 20x10 front, I ran a 285/35, on the rears 20x11 I ran a 315/35 with no issues, lowered 1.25 on Pfadt springs. I also fitted a 335/30 MPSS on the rear wheels as well, ran them for a while, still no issues. Got new wheels, went wider, 20x10.5 front with 285/35, rear 20x11.5 with the 335/30 MPSS.. Still no issues..
I think mine are 275/40 on 9" front and 315/35 on 11" rear. Keep your tires within 1/2 - 1" diameter or less or the check engine and stable track light up.
2011 Synenergy Green 2SS/RS Automatic.
Hulk is offline   Reply With Quote
Old 04-23-2024, 10:09 AM   #366
E.T.
E.T.'s Avatar
Drives: 2012 Camaro 2SS/RS
Sweet, that's good to hear. If I go wider (to 315s from 295s) on the back, is there any reason to go wider up front? I'm at 275 now.
E.T. is offline   Reply With Quote
Old 04-23-2024, 11:17 AM   #367
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yep, I ran that setup as well at one time.
1JEWLDSSRS is offline   Reply With Quote
Old 04-23-2024, 11:22 AM   #368
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
No, no need to go wider unless you want the front to look lower, in which you can go 285/35 like I had on my 10 inch wheels when they were on there. Are your fronts 9 inch wide? If so, you can just stay with the 275's..
CAMARO WIKI Tran Wiki 66 04-22-2024 11:41 AM
Drag Racing Suspension Kits Info@PeddersUSA.com Suspension / Chassis / Brakes 25 02-21-2010 08:48 PM
The Camaro, what it has come to mean for me Number 3 5th Gen Camaro SS LS LT General Discussions 23 04-13-2009 09:31 PM
Answeres to questions I have stumbled on dieseldave24v 5th Gen Camaro SS LS LT General Discussions 13 02-23-2009 06:56 PM
