Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Suspension / Chassis / Brakes
Old 09-22-2022, 11:47 PM   #1
southerncarparts
southerncarparts's Avatar
Drives: 2009 Corvette Z06
2016-2019 CAMARO SS AFE CONTROL SWAY BAR SET 440-402002-N
https://www.southerncarparts.com/201...-402002-n.html
Southern Car Parts is an authorized dealer of aFe products. aFe Control built this Swat Bar Package specifically for the 2016-2019 Camaro SS. If you are ready to increase the handling and performance in your 6th Generation Camaro then you are ready for aFe Sway Bar kit.
Anyone can make a stiff sway bar, but at aFe Control we provide you with the perfect balance by pairing the proper size front and rear bars together to offer increased roll stiffness without upsetting the vehicle's balance and traction control system. Designed specifically for the Gen 6 chassis, the lightweight tubular swaybars will transform your Camaro's handling and inspire driving confidence.
Cornering will be flatter and neutral in any corner. Perfectly balanced, the 35mm, 2-way adjustable front and 32mm 3 way adjustable rear bars are constructed from lightweight tubular steel and feature precision CNC machined, TIG welded bar ends for a perfect fit. The kit includes CNC machined 6061-T6 bushing brackets and polyurethane bushings.
For years of durability and great looks, the bars are powder-coated a special 2 stage tangerine orange. Perfectly Balanced, aFe Control sway bars will have your Camaro handling just as good at the track as it will around town.
aFe Control Suspension products are engineered and manufactured in our Corona, California manufacturing facility.
APPLICATION: 2016, 2017, 2018, 2019 CAMARO
southerncarparts is offline   Reply With Quote
Old 12-31-2022, 02:36 AM   #2
southerncarparts
Thank You for shopping at https://www.southerncarparts.com/201...-402002-n.html
