TireRack
Old 03-18-2018, 04:02 PM   #1
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
Front strut bolt torque procedure??? Sounds weird to me..
It says in the manual to torque the 24mm nut to 59 ft lbs and then to turn it another 180 degrees?????????? WHY? Why not just give it one torque spec and be done with it??????
Also......watching this video they spin the nut 180 degrees but it looks like they are not holding the 24mm bolt head??? So wouldn't the bolt just spin 180?
https://youtu.be/jXuoPUC7xMw
Does't make sense to me.....does anyone know the correct procedure and why they do it this way????
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned|
God is too good! I don't deserve it, but I sure will accept it!!!
ZX1truth is offline   Reply With Quote
Old 03-18-2018, 06:22 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
TTY bolts (torque to yield) supposed to be one time use. Many just Torque to about 80 ft. Lbs. and use blue loctite.
Many bolts are TTY on our cars... TTY with angle ° are supposed to be more exact. Head bolts are that way also. One time use and in that’s case, always replace them.
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari
See My Build: http://www.camaro5.com/forums/showthread.php?t=385577
hammdo is offline   Reply With Quote
Old 03-18-2018, 06:28 PM   #3
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
-Don
Thanks Don......I'm putting Ground Control camber plates on my Pfadt coilovers. So if you go to 59 ftlbs then spin it another 180 degrees make sure the bolt does not spin then. In other words keep the wrench on the head of the bolts and spin da nut?????
Old 03-19-2018, 05:54 AM   #4
KillboyPowerhead
Drives: 2015 Z/22
If you're replacing the bolt then you can use those torque specs (59 ft/lb + 180°) but if you're reusing the bolt then typically you'll give it a grunt or two with some blue loctite as mentioned.
If you do the 59 ft/lb + 180° on a used bolt you may stretch the bolt even more and risk snapping it (bolts stretch when torqued past a certain point, and stretching them again will put them even closer to snapping). TTY bolts are used to make sure a bolt goes on as tight as it needs to; if there is rust in the threads, for example, going to 80 ft/lb or whatever may not make the bolt as tight as it needs to be, but doing 59 ft/lb then 180° makes sure it's tight, no matter the resistance.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
KillboyPowerhead is offline   Reply With Quote
Old 03-19-2018, 12:51 PM   #5
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
Thanks for the input...........very much appreciated!
Old 03-20-2018, 09:42 AM   #6
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
You'll find more information here: http://www.jpssonline.com/t-camaro-a...fications.aspx
JusticePete is offline   Reply With Quote
Old 03-22-2018, 10:23 PM   #7
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
Thanks Pete!
Old 03-26-2018, 10:04 AM   #8
JusticePete
My pleasure
Old 12-23-2022, 12:19 AM   #9
G5ZL1
Drives: 2013 ZL1, 2017 SS
Is the link to more information still live Pete? Trying to get more information on changing front MRC struts-such as which nuts/bolts are needing to be replaced as they are single use.
G5ZL1 is offline   Reply With Quote
Old 12-25-2022, 06:41 AM   #10
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Pretty sure Pete went out of business. I have not seen him on here in quite a while.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
CamaroCracka is offline   Reply With Quote
Old 12-25-2022, 07:27 AM   #11
Badfinger
Badfinger's Avatar
Drives: 2010 2SS
I'm not sure about the camaro but some strut bolts are directional as well. Make sure you put them in the same direction they came out.
Badfinger is offline   Reply With Quote
