08-01-2016, 07:14 PM | #15 |
Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
I believe Glen was merely advising the OP that another thread with helpful information also existed. Uncalled for is a bit of a stretch.
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
08-01-2016, 07:22 PM | #16 |
SABIO
Not normal. Never had that happen to me.
08-01-2016, 07:52 PM | #17 |
Drives: 2018 ZL1 Join Date: Feb 2016
I understand. I just feel that we can be more helpful than just saying there was another topic discussed on this now go find it. We all know what it feels like to have an issue and need help asap. So if you are aware of it being an issue that has been discussed before, why not just offer the answer or a link to the answer? I only mentioned it because I see it a lot on this forum where people are quick to say "do a search" and sometimes that needs to be said. But I don't feel it was necessary on this occasion
08-01-2016, 08:26 PM | #18 | |
Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
2013 Camaro SS 1LE - Black - M6 - Sold 2016 Camaro SS - Mosaic Black - A8 - Sold 2017 C7 Stingray - M7 Coupe - Sold 2019 C7 Grand Sport M7 Vert - Sold 2021 Camaro ZL1 - Black - A10 - Sold 2019 Tesla Model 3 2022 CT4-V Blackwing - M6 |
08-01-2016, 09:48 PM | #19 |
Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
Yeah either battery or starter issue
08-01-2016, 10:19 PM | #20 |
Drives: 1SS HBM w/MRC NPP Join Date: Apr 2016
OP said he couldn't find it when he search, so if he seen the damn thing then he should post it instead of being a baby about it.
08-02-2016, 11:31 AM | #21 |
Drives: 2017 ZL1 and 2018 SS 1LE Join Date: Oct 2015
Well the dealer said they fixed it but they only made it worse here is a video https://youtu.be/BQNHkKV0Ujg after dealer
08-02-2016, 11:54 AM | #22 |
Drives: Gen 6 Camaro RS Join Date: Dec 2015
08-02-2016, 12:10 PM | #23 | |
I had a starter go bad in a 2002 corvette but it would not fire at all or work fine. Once replaced all good. I think heat killed it and some suggested wrapping it with a heat shield.
08-02-2016, 01:58 PM | #24 |
Drives: 2016 2SS A8 Non-NPP Join Date: Jul 2016
I've had both batteries and starters that have tested good but we're in fact bad and only found out after replacing then anyway.
If you need to park next to a new one and compare how they start for the techs, may be what you have to do. I have had service departments go down a checklist and tell me by car (not my Camaro) was fixed when there was an obvious cylinder miss. It sucks when diagnostics does not fix it for them. It isn't right. You'll never make it in the cold. |
08-02-2016, 02:21 PM | #25 | |
Drives: 1969 Mustang MaCh1 Join Date: Nov 2015
I had a pulley seize before. Disconnect the belt and try starting it, see if it still hard starts.
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtqT56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear |
08-02-2016, 02:52 PM | #26 | |
I would be afraid to be too far from home with your car as that sounds like a car that will not start the next time. Good luck! BTW - what did they supposedly fix?
09-22-2016, 05:33 PM | #27 |
Drives: 2016 Camaro 1SS Join Date: Jan 2016
My car did this today. It wasn't anywhere as extreme as the OP's, but when it first started to crank it was identical to the OP's original video. After the first try and a crank and kinda long pause, it then finally started to crank more normally and then fired up ok. This only happens after driving the car a long time and it being very heat soaked, shutting the car off, then trying to crank it again a few minutes later. It always starts slowly in this situation, but nowhere near as bad as today.
OP what's your update? Did the dealer ever fix it and if so what was the issue?
2016 Nightfall Gray Metallic 1SS 6MT, Edelbrock E-force supercharged, Killer Chiller with 3-way bypass, catch can ***FOR SALE, MESSAGE ME IF INTERESTED***
Previous: '12 Mustang GT 6MT (12.47 @ 115.88) '09 G8 GT (11.86 @ 120.47) '05 GTO 6MT (slow, lol) '01 Grand Prix GTP converted to turbo, high 11's |
09-22-2016, 08:20 PM | #28 |
Drives: 2016 camaro 1SS Join Date: Jun 2015
Mine isn't as bad as the OP but I do notice it doesn't turn over as fast as when it is cold started
