09-10-2015, 09:27 PM | #1 |
Drives: 2013 Camaro Ls Join Date: Sep 2015
2013 Camaro LS Radio Problem Help Please
What's up everyone! I have a issue hopefully someone can point me into the right direction
I have a 2013 Camaro Ls that has a amp & subwoofer setup.. Everything was good until I hit bump and my radio started to intermittely cut off with my A/C. Would go out for few seconds sometimes minutes. I brought it into Chevy thinking its the BCM they told me that it's not the BCM tried to replace the radio twice but not having any luck. They had my car for a week, and just realized there is a Amplifer mounted to my back seat..***NO POWER IS GOING TO IT*** I took out the fuse by the battery before leaving it there... Now there saying it's the amp that's shorting the radio.. Gave me my car back told me to make it stock again and bring it back.. -__- I just don't know what to do now... The radio doesn't even come on now no matter what I do.. Anybody have a similar problem? |
09-11-2015, 09:59 PM | #2 |
Drives: 2013 2SS/RS/1LE Join Date: Apr 2010
First thought would be a wiring issue. The first step would be to disconnect the amp as noted. Troubleshooting is often just a process of elimination.
09-11-2015, 10:47 PM | #3 | |
Thx
I have my fingers crossed |
10-19-2016, 06:15 PM | #4 |
Drives: Victory Red 2013 2LS Join Date: May 2016
Has the dealership said anything yet? I'm having the problem of the radio cutting out, but i haven't added a sub or speakers
10-19-2016, 08:06 PM | #5 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Should have gone back to the shop that installed the amp.
Power is worthless without control. The 2nd protects the 1st.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
Tags |
5th gen, problems, radio, radio harness |
