Roto-Fab
Old 08-22-2017, 11:52 PM   #1
2015 Camaro Ss 1le
Drives: 2015 camaro ss 1le
Brembo brake pad change suggestions
I know there is already thread about Brembo brake pad squeaking noise at very light speed breaking. I have 22k miles on my car. I just want to know when I should change my brake pad as this squeaking noise confuse with the GM noise brake pad indicator. I had my brake pad checked at 16k miles it was 8mm at that time. Can anyone share experience how many miles they get with OEM brembo brake pads? I mostly drive in city and we have heavy traffic in Atlanta. And also can you suggest best brake pads?
2015 Camaro Ss 1le is offline   Reply With Quote
Old 08-23-2017, 03:13 AM   #2
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
37k for me. No tracking during this time just spirited driving and a few trips to the drag strip.
CamaroDreams76 is offline   Reply With Quote
Old 08-23-2017, 06:32 AM   #3
14Black1LESS
14Black1LESS's Avatar
Drives: 2014 2SS/RS/1LE
The squeaking got on my nerves so I changed mine to ceramic pads. I would suggest getting ceramic pads next time.
14Black1LESS is offline   Reply With Quote
Old 08-23-2017, 09:22 AM   #4
sspade
sspade's Avatar
Drives: 2015 Camaro LFX A6
Can someone confirm if these pads can be swapped out without removing caliper?
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
sspade is offline   Reply With Quote
Old 08-23-2017, 09:26 AM   #5
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
They can! Just tap the pins out and the pad comes out the top.
gajagfan is offline   Reply With Quote
Old 08-23-2017, 12:10 PM   #6
2014white2ssrs1le
2014white2ssrs1le's Avatar
Drives: 2014 white 2ss rs 1le
you might lose a little performance with a ceramic pad...has anyone tried the stoptech sport pads? GTO guys love them.
2014white2ssrs1le is offline   Reply With Quote
Old 08-23-2017, 12:29 PM   #7
PK Auto Design
PK Auto Design's Avatar
Drives: 2017 Chevrolet SS 1LE
Hawk Ceramic pads are awesome if I may suggest.
PK Auto Design is offline   Reply With Quote
Old 08-23-2017, 12:30 PM   #8
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
If you wait until they squeal to indicate it's time to change, you risk damaging your rotors. OEM pads are excellent for normal and spirited driving, and will last a long time. Try pulling your wheels off and looking at them to see "exactly" what you have left.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 08-23-2017, 01:44 PM   #9
14Black1LESS
That's what I ended up getting.
Old 08-23-2017, 01:44 PM   #10
PK Auto Design
Their good arent they
Old 08-25-2017, 01:49 AM   #11
CamaroDreams76
Since I did my pad and rotor change, I've had zero squeak. I replaced them with OEM and made sure I bedded them.
Old 08-25-2017, 06:19 AM   #12
14Black1LESS
The best I have come across so far. Been using them ever since I had my '02 Vette.
Old 08-26-2017, 01:25 PM   #13
markgws6
markgws6's Avatar
Drives: 2019 Chevy Equinox Premier AWD
Hawk pads have been good for me and are a decent improvement over the stock pads (for the street). I got hawk street 5.0 pads and two piece racing brake front rotors and this combo works great with no noise. However, I did take them to the track once and my brakes got really hot and they failed, so keep it on the street if you go with either Hawk ceramic or 5.0 street compound. (I too drive in heavy stop and go traffic every weekday here in the bay area.)
2013 AGM 1SS/1LE, NPP, Camera
(1 of 43)
markgws6 is offline   Reply With Quote
Old 08-27-2017, 03:35 AM   #14
CrystalRedTintcoat
CrystalRedTintcoat's Avatar
Drives: 2013 2SS 1LE NPP GBE
I went to Hawk DTC-30 in the front and HP+ in the read and have since switched back to Brembos; they are good pads.
The DTC-30 chewed into my rotors and I had to replace them. But that setup made our heavy car feel like a feather-light Honda when braking.
The best thing I've done is to go to the 6 piston front caliper with the brembos. Stops really well now.
2013 1LE NPP GBE
Mods
Track Days
CrystalRedTintcoat is offline   Reply With Quote
