Old 10-13-2014, 06:47 PM   #1
RogerStout
RogerStout's Avatar
Drives: 18 ZL1 Summit White
LT4 supercharged?
You really think they are going to drop this motor in the 6th gen zl1? I will be first inline to order one at my local dealer if so..
RogerStout is offline   Reply With Quote
Old 10-13-2014, 06:48 PM   #2
HDRDTD
I doubt it. It'll be reserved for the Corvette I'd think. At least for a year or two.
Old 10-13-2014, 06:50 PM   #3
RogerStout
RogerStout's Avatar
They would continue to use the LSA?
Old 10-13-2014, 06:58 PM   #4
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
Well there's little doubt the 2017 50th anniversary will not be a promising vehicle. I'm expecting them to put some massive HP in this so an LT-4 is not wishful thinking.
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 10-13-2014, 07:10 PM   #5
ilirg
ilirg's Avatar
Drives: 2011 Camaro 2ss
Not a doubt in my mind the lt4 will be in the 6gen zl1
ilirg is offline   Reply With Quote
Old 10-13-2014, 09:02 PM   #6
DenverTaco07
DenverTaco07's Avatar
If they do a ZL1 or equivalent....I don't see chevy not throwing a SC on the same platform, LT1. Don't see how anything else makes sense.
Assuming the LT1 Is going in SS.
So yes...LT4.
Old 10-13-2014, 09:13 PM   #7
Bhobbs
Bhobbs's Avatar
I bet we see some version of the LT4, just most likely not one with all 650 hp/lb ft.
Old 10-13-2014, 09:30 PM   #8
DenverTaco07
649 sounds good
Old 10-13-2014, 09:45 PM   #9
RogerStout
RogerStout's Avatar
I dont mind the detuned LT4, Nice if the made it simple to add the power back in...
Old 10-13-2014, 11:06 PM   #10
Bhobbs
Bhobbs's Avatar
Originally Posted by DenverTaco07 View Post
649 sounds good
I'm thinking 600/600 is about right.
Old 10-14-2014, 11:06 AM   #11
DenverTaco07
I know it's been stated many times, but remind me of the potential weight loss on the 6th Gen again.
I think a new ZL1 with >580 HP /556 Lb-ft, and 3820 weight is....
ok, some math...
5th Gen 580/4120 gives power to weight of .141
6th Gen 600/3820 (assumption) gives power to weight of .157, a 12% increase.
625 HP = .164 P to W, a 16% increase
640 HP = .168 P to W, a 19% increase
Someone check my math - i rounded up.
Anyway, don't know if we are gonna get 300lb diet or not, but a 15% increase should suffice.
Old 10-14-2014, 11:28 AM   #12
RLHMARINES
1st Civ. Div.
RLHMARINES's Avatar
Drives: Camaroless for now...RIP "Big SexZ"
I believe with the proposed rear engine Zora Corvette ZR1 coming soon with a lot more hp than the '15 Z06's 650 rating, it should be safe to think that the LT4's hp rating when installed in the 6th gen will not be detuned for any reasons.
Swift....Silent....Deadly
RLHMARINES is offline   Reply With Quote
Old 10-14-2014, 07:23 PM   #13
hotlap
hotlap's Avatar
I don't see the LT4 Z06 as the end of the Corvette story.
Ronald Reagan -
Old 10-14-2014, 07:32 PM   #14
Bhobbs
Bhobbs's Avatar
I would be shocked to see a mid engine Zora any time soon. I just don't see how GM can build a mid engine car on the C7 chassis. That would require modifying everything forward of the transmission. It would be a 75% brand new structure.
We haven't seen any mid engine mules running around and, with GM never having built a production mid engine car, I'm sure they would have to do a lot of testing.
Until I see a mid engine Corvette Zora ZR1 on stage I won't believe it. Same goes for a Camaro with the full potential of the LT4, as it sits now.
