Old 03-29-2017, 01:43 PM   #15
EFI Tuning
EFI Tuning's Avatar
Drives: 2016 Camaro SS
Not enough are
EFI Tuning is offline   Reply With Quote
Old 03-29-2017, 02:07 PM   #16
JFM-jr
JFM-jr's Avatar
Originally Posted by EFI Tuning View Post
Not enough are
There will be another 1 shortly! Tim you have any idea how hard the stock pump is being pushed with a full bolton E85 setup? I know there cant be much room left but is it working the pump at its ceiling?
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 03-30-2017, 07:41 AM   #17
Old 03-30-2017, 07:52 AM   #18
Infern0
Bring It
Infern0's Avatar
Drives: In Between
Ok, I spoke to the Chief Engineer for Small Block. Some good news / bad news here....
GOOD NEWS:
When LT1 added Direct Injection, the hardening processes were added, so all small block V8s get the hardened valves, guides, and seats, so no risk of ethanol corrosion or pitting
BAD NEWS:
If you do not add the fuel sensor, you run a very high risk of mismatched air fuel calibration, leading to likely pre-detonation. I've noticed that most of you talking about using E85 are aware of the need to add the sensors.
MORE BAD NEWS:
The fuel pump in the LT1 does not have the capacity to manage the flow volume required to fully take advantage of E85. It requires more volume than gasoline or E10. His suggestion is to save the expense of the E85 sensor and just use octane boost. It will probably result in the same level of performance.
Hope that was helpful.
Happen to also know about the LT4?
Infern0 is offline   Reply With Quote
Old 03-30-2017, 07:56 AM   #19
Fraxum
Fraxum's Avatar
GOOD NEWS:
BAD NEWS:
MORE BAD NEWS:
Yes! Interesting.
Thanks for the not running E85 tip without the sensor and tune. I was going to start using it to get my E85 concentration up when I add the sensor.
So cars picking up 30 RWHP with E85 could get more with more pump and stock injectors? If so would Prays car go 130?
E85 and the flexibility of the sensor/tune is more convenient than high octane gas and switching tunes IMO.
Old 03-30-2017, 08:04 AM   #20
Fraxum
Fraxum's Avatar
It has more pump and injectors I think. And wondering how E85 will pump up the LT4. Will ZL1s be able to hunt down Demons?
Old 03-30-2017, 09:21 AM   #21
JFM-jr
JFM-jr's Avatar
Its also forced induction so the potential to pickup more HP vs an NA setup is there but so is the fuel demand. Id imagine a ZL1 on E85 is going to need alot more fuel as an overall % over stock vs an NA car.
Rotofab
11.0@124.9
e85, octane, race, track, tune
