04-11-2016, 09:12 PM | #1 |
Drives: 2011 camaro 2SS RS Join Date: Apr 2014
spark plug tip on eletrode missing???
As title say small tip on the electrode is missing
it started idling rough so i pulled the plugs and 5 out of the 8 the tips where gone the car has 38,000 miles and about 1500 miles on cam and new tune do i need a cooler plug maybe? http://www.camaro5.com/forums/attach...ntid=788191&st http://www.camaro5.com/forums/attach...1&d=1460426799 |
04-11-2016, 09:39 PM | #2 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
With just a cam, don't really know why you'd need a colder plug. Stock should still work. That said, the plug color looks pretty good, and that reddish color is just from fuel additives. While they should have lasted longer than 30k miles, I would drop a new set of OEM's in there, and check them in a 1000 miles.
Do you run the hell out of it regularly?
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
04-11-2016, 10:50 PM | #3 |
Drives: 2010 ss/rs Join Date: Feb 2016
mine had one that was missing a tip and was running rough at 45k
http://www.camaro5.com/forums/showthread.php?t=447021
2010 2ss/rs ls3 dynatech longtubes/exhaust, CAI intake, mgw short throw, pfadt coils, ds i1000 tuned by dynosteve, taylor 409 race wires, elite catch can, bfg comp 2 tires,
04-12-2016, 04:12 AM | #4 |
replace all those with new AC Delco 41-110 plugs
04-12-2016, 05:17 AM | #5 |
Drives: 2012 SS L99 Converible Join Date: Mar 2016
Are the 41-110 recommended only for modded cars or will they work on stockers with just a tune, cai, and axle back
04-12-2016, 05:37 AM | #6 |
41-110 are the stock plugs. there is no need to change plug unless going forced induction or raising the compression ratio
04-12-2016, 06:13 AM | #7 |
i do not run it hard regularly but last saturday i did take 5 differnt familey members for a ride so i did run it hard 5 differnt times but not in a row there was 20 mim between runs
04-12-2016, 07:07 AM | #8 |
Drives: 2010 2SS/RS Inferno Orange Join Date: Mar 2013
5 hard runs didn't do that to your plugs. Just replace all of them and monitor. I would pull a few out every 5K-7K miles just to see how they are burning.
U.S. Army Retired |
04-12-2016, 07:29 AM | #9 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Are those stock plugs?
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
04-12-2016, 07:55 AM | #10 |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
spike III Build IBM 1SS/RS [COTW] 6/25/12
04-12-2016, 08:07 AM | #11 |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
This ^^^^^ ... Then I'd check them after about 1K miles.
04-12-2016, 08:26 AM | #12 |
old school chevy rodder
Drives: 2013 2SS/RS Manual,DM exhaust,CRT Join Date: Jul 2012
Or if you are cammed...running TR6ix is the NGK alternative.
04-12-2016, 01:30 PM | #13 |
04-12-2016, 08:28 PM | #14 |
New 41-110 plugs installed and runs fine now i will monitor them in 500 miles and see what they look like
