01-29-2016, 08:51 PM | #1 |
Drives: 2015 2SS/RS vert, Spring Green Edtn Join Date: Jun 2014
Two simple questions
1) How accurate is the DIC for showing tire pressure? I checked mine cold with a digital tire gauge and they showed 36.5, but the DIC showed them at 37 and 38 cold.
2) Can anyone suggest a pump in the $50 - $60 range that I can use at home? I'll only be using it to top off the tires when they need it, not inflating from flat. I have no preference whether it runs on the house AC or the car's cigarette lighter, just something that's reliable, easy to use, and won't take forever to add only a few pounds.
2015 2SS/RS vert, Spring Edition Green Flash (2015 - present)
2014 1LT vert, Blue Ray Metallic (2014 - 2015) |
01-29-2016, 08:58 PM | #2 |
Drives: car Join Date: Apr 2015
Actually the DIC tire pressure (at least on my car) is pretty accurate. Only thing is that it reads 3 lbs lower than actual. Always has. If it says 33 psi then it is 36 psi spot on. It takes a while for them to adjust after the car has been sitting a while but after you drive for about 10 minutes they should read accurately (3 lbs lower than reality) but all 4 tires should read correctly.
01-29-2016, 09:03 PM | #3 | |
Doing what I like to do
Drives: 1963 Landrover Join Date: Nov 2013
01-29-2016, 09:07 PM | #4 |
01-29-2016, 09:17 PM | #5 |
BCS Auto
We put the VIAIR 90P compressor in our vehicles at work, they're heavy duty, quiet and reliable. We use them for off-road driving in nasty conditions, which is why we went with the 90P. Here's a slightly less expensive and more car-centric compressor that's equally reliable (VIAIR 70P). I'd highly recommend this brand.
http://www.amazon.com/Viair-00073-He...air+compressor
01-29-2016, 09:27 PM | #6 |
Drives: 2012 SS/RS Join Date: Jul 2013
I don't trust the DIC too much because when I bought new wheels and left the wheels with TPMS at home it the car didn't know for like 20 miles.
01-29-2016, 09:36 PM | #7 |
I usually trust my DIC although it has gotten me into trouble from time to time over the years. I say if you can't trust your DIC who can you trust?
01-29-2016, 09:37 PM | #8 |
BCS Auto
The only motto to live by. hahaha
01-30-2016, 12:00 AM | #9 |
I bought a fairly nice gauge and found that always reads 1 pound lower than the DIC.
I decided to trust the hand held gauge. Track day, I borrowed a couple of really nice gauges. DIC was right on with both. Now, I trust my DIC, and know I'm a pound short when my gauge is in my hand. |
01-30-2016, 04:26 PM | #10 |
Drives: 2011 Camaro 2SS/RS Join Date: Jun 2011
01-30-2016, 05:02 PM | #11 |
Drives: 2010 SS LS3 S200 56/61 AGP TT Join Date: Jan 2009
01-30-2016, 06:06 PM | #12 |
That never even occurred to me! I'll have to check and see what's there. I previously had a Mazda that came with a can of glorified Fix-A-Flat in lieu of a pump. I guess I'm still in that mindset.
2014 1LT vert, Blue Ray Metallic (2014 - 2015) Last edited by scandata; 01-31-2016 at 06:18 AM. |
01-31-2016, 12:26 AM | #13 |
Jus' Cruzin
Drives: 2017 Camaro 1SS Krypton Green Join Date: Oct 2012
My TPMS system is always anywhere from 2-4 lbs off on airpressure. My tires may be right at 36 but show 33-34 on the DIC
“The moment you think you know what’s going on in a women’s head, is the moment your goose is well and truly cooked”
-Howard Stark |
01-31-2016, 03:40 PM | #14 |
Drives: 2022 Wild Cherry SS Join Date: Aug 2012
Ghosted - Do you have issues getting screw-on chuck on and off the valve stem? My current compressor chuck is hard to remove.
Thanks! |
