Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 11-04-2015, 06:04 PM   #1
Shayne70
Shayne70's Avatar
Drives: 2010 Black 2ss Chevy Camaro
Which Break Pads Do I need to buy??
Hey guys I am going to change my break pads for a 2010 2SS RS, but I am unsure which pads I need to buy. I am going to change them myself. I have the standard stock ones and at 50k miles I think i should change them. I don't break quick or go on tracks so regular pads are fine.
Thank you for the help
SHayne
Shayne70 is offline   Reply With Quote
Old 11-04-2015, 08:21 PM   #2
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Stay OE and shop for the best prices.
JusticePete is offline   Reply With Quote
Old 11-05-2015, 12:45 AM   #3
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
You "think" you should change them? Just look at the wear tabs. Mine are fine and I have 43k
2011 2SS/RS built 8/24/10
rebelyell22 is offline   Reply With Quote
Old 11-05-2015, 08:29 AM   #4
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Drives: '69 Z/28 LeMans Blue w/White
Just changed out my original pads at 55K and went with the exact GM replacements. They are made for GM by Ferrodo and say so on the pads. Rock Auto has them at a good price but you will need to look closely at the description to make sure you pick the right ones. They come in a box with the new hardware but you will need to reuse the shims. They come with the special grease too. You will get the roller skates this time even if you did not have them before.
-Mark.
Stingr69 is offline   Reply With Quote
Old 11-05-2015, 01:30 PM   #5
Shayne70
Shayne70's Avatar
If you have the link for the Pads that you have bought, do you mind sending it please.
Thanks
-Mark.
Old 11-11-2015, 08:05 AM   #6
Stingr69
'69 Owned Since '79
Stingr69's Avatar
http://www.rockauto.com
Part Number 1710882 and part number 1711112 are the right pads to order.
Old 11-18-2015, 08:41 PM   #7
Blakk11SS
Blakk11SS's Avatar
Drives: 2011 Camaro 2SS/RS
fyi, the original equipment Brembo pads are available at http://www.gmpartsdirect.com/
you also get the needed shims and some break grease in small tubes.
the cost online at GMPartsDirect is really good and you're getting oem.
to avoid squealing breaks, see the DIY on pad install here on C5, use plenty of break grease on any metal to metal contact point. you'll have quiet braking for sure.
Blakk11SS is offline   Reply With Quote
Old 11-18-2015, 09:41 PM   #8
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Here brother....this should help.
http://www.camaro5.com/forums/showthread.php?t=135887
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats.
KaBoom1701 is offline   Reply With Quote
