Old 03-05-2024, 02:32 PM   #1
JSH
JSH's Avatar
Drives: '20 ZLE
Trailer Tie Down Methods
I'll be hauling the car in a rented 20-24 ft. single-car hauler that will either have four tie-down rings or E-Track connections. With previous cars, I put a tie-down strap thru each wheel such that it pulled against the wheel, not the spoke, and tightened it down with a ratcheting strap.
Wouldn't you think a 6' or 8' ratcheting strap would be long enough for a trailer of this length?
Have you found a better way to tie-down a Camaro?
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
Old 03-05-2024, 02:43 PM   #2
split_bumper
Drives: 24 ZL1, 6.2L Denali, 73 SplitBumper
I have my car in my trailer for storage and this is how I had to tie it down. The front I went with an axle strap around the lower control arm, the rear, there was no where easy to tie it down to, the plastic shields around the lower arms make it hard to use axle straps. I ended up having to go around the rims like you mentioned for the rear. I also had it up on some blocks to get some extra room underneath to get straps on. I will follow along to see if anyone else has some better ideas.
If you can get longer straps go with them, having more rather than not enough won't hurt.
2024 ZL1 Radiant Red / Coupe / M6 / PDR / BCD / Carbon Scoop, Dash, Shifter / Red Seat Belts / Black Lugs
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R60R0111531
split_bumper is offline   Reply With Quote
Old 03-05-2024, 05:03 PM   #3
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I tie down through the wheels as well. Seems to work out well.
Old 03-05-2024, 05:43 PM   #4
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Any connection that eliminates the suspension is a good tiedown point
Old 03-05-2024, 05:55 PM   #5
CalgaryZL1
CalgaryZL1's Avatar
Front and rear strap points if you don’t want to touch the tires, and you don’t need much downforce. The car was designed to be planted already.
Old 03-05-2024, 06:33 PM   #6
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
I prefer over tire method onto e-track or J-hooks (turn n lock type) into the "frame rail".
Always afraid that pulling wheels away from body would mess up the alignment.
ing for grip.
http://www.motorsportsne.com/
Old 03-05-2024, 07:01 PM   #7
CalgaryZL1
CalgaryZL1's Avatar
Good point ! I forgot about the over tire strap/net. The bottom line is avoid suspension load.
Old 03-05-2024, 10:25 PM   #8
JSH
JSH's Avatar
Drives: '20 ZLE
Yeah, that's right. I've been thinking of having to use a 24" strap thru the wheel connected to a ratcheting strap but you've avoided that setup
'20 ZL1 1LE A10,
