Old 03-02-2024, 12:19 PM   #1
Steve65
Drives: 2013
Thermostat.???
Have 2020 3LT convert....today when went for drive the temperature gauge didn't move and when turned car off the fan stayed on a other 5 min. Any ideas
Steve65 is offline   Reply With Quote
Old 03-02-2024, 01:55 PM   #2
OB0001
2018 SS A8 11.85@117.06
OB0001's Avatar
Drives: 2018 Camaro SS A8 "Dark Knight"
check coolant level
DARK KNIGHT
2018 SS A8 11.85 @ 117.07 GPI Tuned E85 stock tires Roto Fab CAI LT 2 intake
OB0001 is offline   Reply With Quote
Old 03-02-2024, 03:13 PM   #3
Thermostat and/or temperature sensor, a relatively frequent failure. My conjecture is that the thermostat may have stuck open, the engine was never able to warm up with the cooling continuously on, and the (low) coolant temps you saw were correct.
The fan staying on for 5 minutes after shutting the car down is a failsafe: the ECM thinks the values it sees from the temperature sensor are unexpected or not realistic for some reason and tries to avoid the worst case scenario.
Old 03-02-2024, 06:44 PM   #4
MrCharlieV
Drives: Camaro RS
Thermostat. I had the same issue. 2016 V6.
MrCharlieV is offline   Reply With Quote
Old 03-05-2024, 08:29 AM   #5
easttxss
easttxss's Avatar
Drives: '16 2SS M6
When the thermostat sticks open, even just a little bit, the engine doesn't warm up in the amount of time that the ECM is expecting. The ECM throws a code, the gauge goes to zero, and the fan is turned on high. This same scenario can happen with a bad coolant temp sensor (which was my case). Clearing the code will make the gauge and fan work correctly until the ECM sees the fault again.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB
'16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20)
'14 Fusion Titanium 2.0T
'83 Jeep Wagoneer
easttxss is offline   Reply With Quote
Old 03-09-2024, 11:49 PM   #6
MyNameIs
Drives: Camaro SS
Thermostat. Mine is a 17' SS, 68k miles. Same thing happened to me 2 months ago. Picked a Thermo. from the dealer and put it in in about an hour, problem solved. Dealer parts guy said recommended replacing every 3 to 5 years with average yearly driving so I got I got 7 years out of mine. The bad news for you though is I heard the V6 is more involved. I think the C6 V6 you have to remove the intake to get to the Thermo.
MyNameIs is offline   Reply With Quote
