01-21-2024, 05:28 AM | #1 |
Bought a 2011 Camaro 2SSRS 6 speed manual from IAA auction in Washington this week
Bought a 2011 Camaro 2SSRS 6 speed manual from IAA auction in Washington this week. Has 80K miles on it. I'm using it as a donor for my 1973 Camaro project.
Anyone know this car? I know it was bought new in Utah then sold in Washington in 2021. Here's my 1973 Camaro.
It's nice to have options.
01-21-2024, 08:00 AM | #2 |
Drives: 2012 Camaro 2SS/RS Vert LS3/M6 Join Date: Aug 2021
Did you do the bumper conversion on your 73? What you taking off the 5th gen? Pretty cool project!!
01-21-2024, 08:34 AM | #3 |
wow,that 5th gen looks pretty good to be chopping up...is the other side toast?
01-23-2024, 08:05 AM | #4 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Agree! ^^
01-23-2024, 09:28 AM | #5 | |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
You can make some decent money back parting that car out with things like the CF hood, Heritage grille, bumpers, convertible parts, etc... This is the best way to do this. Lowers the overall cost of your swap. If I ever LS swap a thirdgen again, I will be buying a 4th gen as a donor car since 90% of the car bolts directly to the thirdgen. Good luck!
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
01-26-2024, 01:39 PM | #6 |
The 2011 arrived in much better condition than expected. Has a bent lower control arm & bent strut. Paid $166 for a pair on new struts & a lower control arm. Also bought a full set of Camaro 18" & pair of 20" for $100 & selling the 18" for $150 netting me some free 20". Should have the 2011 driving next week. As is I did drive it into the garage. Engine started right up and ran 90 minutes with no issues.
Only body damage is front bumper cover & passenger side ground effects are off but I have it. No dents or scratches on the paint. Convertible top looks like new.
01-26-2024, 02:03 PM | #7 | |
The 2011 is donating its engine, transmission, all seats, center console, gas/brake/clutch peddles, heat/ac system, radiator, fuel system, brake booster, full wiring harness, steering column, gauge cluster and transmission tunnel since thT TR6060 is so big. The 73 will have working OBDII and think it's a 2011 Camaro.
01-26-2024, 02:08 PM | #8 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
I'm not going to fault you for using that car as a donor! It's gonna be a work of art when you are done!
You should do a build thread so we can follow along!
01-26-2024, 03:53 PM | #9 |
2&THEHIT
Ditto. I do love a 2 gen
01-27-2024, 12:13 PM | #10 |
Drives: 2010 Synergy Green Camaro 1LT Join Date: Jun 2019
OOoo the heritage grill..
Is that Cyber gray? |
01-27-2024, 02:50 PM | #11 | |
01-31-2024, 05:05 AM | #12 |
The 2011 arrived & in much better condition than I was expecting. Extra bonus is the carbon fiber hood. It started right up and was able to drive it off the trailer then in to the garage.
01-31-2024, 06:07 AM | #13 |
It don’t come easy.
Sure you want to part the ‘11 put for the project car? From the initial post, would have figured the ‘11 was salvaged. Doesn’t sound like it.
02-03-2024, 11:09 AM | #14 |
Drives: 2013 Camaro SS Join Date: Feb 2024
I'm curious to know what you can use off the 2011 for the 73?
2013 Chevrolet Camaro SS (My first baby and now my weekend car)
2023 Chevrolet Silverado Custom 4WD (Negotiated $10K off, I brag about every chance I get) |
Tags |
2011, auction, camaro |
