Old 11-13-2015, 03:38 PM   #71
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Originally Posted by Zeke.Malvo View Post
Your post says that it's blocked off. But if you pause the video, you can clearly see that it's STD correction factor, vs SAE correction for the still image. That will account for the majority of the difference.
Never bothered to pause it, but since their numbers were a little higher then all the rest, I assumed it was uncorrected, hence my post. But depending on the weather, uncorrected can at times actually be lower. SAE with a smoothing of 5 is what I always make sure my dyno shop uses as it gives the best numbers for comparison and consistency.
Old 11-13-2015, 04:15 PM   #72
Zeke.Malvo
Zeke.Malvo's Avatar
Drives: 1969 Mustang MaCh1
Right. I was just pointing out the difference in correction factor used is all. Nothing earth shattering on my part, just pointing it for others who may raise an eyebrow due to the differences. Obviously you know what's up.
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtq
T56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear
Zeke.Malvo is offline   Reply With Quote
Old 11-13-2015, 04:26 PM   #73
NASTY99Z28
Drives: 99z28 with bolt-ons and a mwc fab 9
If you notice on the vid, the 417 rwhp is with STD correction factor and the 399 is with SAE.
It's also been stated that it was getting spark knock and pulling almost 2 degrees of timing so they splash it with some race gas.
I like my woman like my milk shakes, THICK!!!!
NASTY99Z28 is offline   Reply With Quote
Old 11-13-2015, 05:16 PM   #74
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Yeah, my guess is the car didn't have 93 in it, it pulled 1.8*, which isn't a lot, and would fit a lower octane fuel being used. Or, possibly a bad batch of non top tier fuel...
Old 11-13-2015, 05:20 PM   #75
brutusvk
Drives: future 2016 SS
I am betting it mostly had 87 in it. Most factory tunes are meant for 91 octane, not 93. Too many markets do not have 93 available. In my Z I had a group of maps for 91, 93 and 100 octane. I would mix race with super when needed. A lot of dealers fill up their cars with crap gas.
brutusvk is offline   Reply With Quote
Old 11-13-2015, 05:25 PM   #76
Zeke.Malvo
Zeke.Malvo's Avatar
Correct. It's well known and documented (it's a straightforward formula) that an STD correction factor results in ~4% higher readings than SAE. So roughly 16rwhp is from the correction factor alone. The other 2rwhp or so probably from the octane difference.
Old 11-13-2015, 06:52 PM   #77
NASTY99Z28
What makes you think that they would use two different direction factors between pulls? FYI they don't do that. Also its been said the only difference was a spash of race gas to help with spark knock. What we don't know is if it had it because of fuel (87,89,91,93) or it was just a warm engine that pulled 2 degrees. I will say though that 417 is a fluke number and can't be repeated. If it did then I'd say its a very generous dyno or a ringer and you can't deny that.
Old 11-13-2015, 07:32 PM   #78
aa406079
Drives: New : 2017 SS 1LE Old: 2012 TTRS M6
Originally Posted by Vdb209 View Post
Just got the invoice on my 1ss and the shipping weight reads 3,603 lbs
I imagine dealerships top off the tank to save transport costs for GM
aa406079 is offline   Reply With Quote
Old 11-13-2015, 09:13 PM   #79
Zeke.Malvo
Zeke.Malvo's Avatar
Did you not watch the video? It's clear that the correction factor used on the video was STD. It says it on the screen just before it zooms in. Very simple stuff here people lol
Old 11-13-2015, 09:28 PM   #80
Zeke.Malvo
Zeke.Malvo's Avatar
Old 11-13-2015, 10:23 PM   #81
Memphis43
Memphis43's Avatar
Drives: Chevy
Yes.
Memphis43 is offline   Reply With Quote
Old 11-13-2015, 10:27 PM   #82
Memphis43
Memphis43's Avatar
Drives: Chevy
That would put the weight of his SS around 3750. What options are on that 1ss?
Old 11-14-2015, 10:49 AM   #83
Ragnar
Destroyed by flooding
Ragnar's Avatar
Drives: Wife's car
Not sure about Gen 6 SS, but Gen 5 SS has two trim levels for fuel. A lot of discussion about this, here is a link. What octane fuel does the factory put in?
http://www.camaro5.com/forums/showth...fuel+fuse+pull
Old 11-16-2015, 07:57 AM   #84
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Pretty common on these new cars, but this (gen 5) seems to be more effected by it then most other cars. Interesting...if the gen 6 has this set up the same way, it could surely come into play on a dyno run made right after a fuel swap.
