Vararam
Old 04-22-2015, 08:54 PM   #1
Jake0021
Jake0021's Avatar
Drives: 2013 Ashen Gray 2SS
Solo high flow cats question
Hello, I'm thinking about buying some solo high flow cats off a member here, but was told by someone who is very knowledgable in camaros that they will eventually throw codes in a few months. Is this partly true? I'm not sure if I want to risk it, but if this hasn't happened (with correct install) I'm all for it. Anyone had them for 1 year +? Btw I have the L99.
2013 Ashen Gray 2ss L99, 20" Giovanna Shaki, 315/275 Nitto Invos, Texas Speed 1 7/8'' Headers, Lingenfelter Axleback Dyno tune by PowerFab, Black Heritage Grill, Oracle Afterburners 2.0 P13W fogs with DTRL harnesses, Night Owl Halo kit, Cold Air Inductions Intake, Lingenfelter Axleback Phastek rear blackout kit
Jake0021 is offline   Reply With Quote
Old 04-22-2015, 10:25 PM   #2
F-16 Camaro
Drives: 2010 Camaro 2SS Black
Some people have experienced rear O2 sensor codes with the solo's but most have not.
I have JBAs which everyone said would throw codes, and they did.
I added: http://www.bigdaddiesgarage.com/straight-cel-fix.html
And no more codes.
I believe Solo HF cats come with an extender like this which explains the rarity of Solo's throwing codes.
I hope this helped!
F-16 Camaro is offline   Reply With Quote
Old 04-22-2015, 11:14 PM   #3
Mrbowtie26
Mrbowtie26's Avatar
Drives: 2015 CRT 1SS 1LE
And no more codes.
I hope this helped!
Think these would work with cat delete pipes to help not throw a code or is this too much to ask ? :-)
Mrbowtie26 is offline   Reply With Quote
Old 04-23-2015, 12:15 AM   #4
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
I have the 2011 l99 ..had the solos for 2 years with no codes. Is it the 2013 and newer cars having trouble with codes?
rontammy0 is offline   Reply With Quote
Old 04-23-2015, 02:18 AM   #5
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Yes 13+ have trouble with codes. Not sure if its only on NPP cars or not.
Op, get the solo extenders and pair them up with the bigdaddies angled extenders. No CEL
CamaroDreams76 is online now   Reply With Quote
Old 04-23-2015, 12:40 PM   #6
Spec
Drives: 2010 Camaro 1SS LS3
I got the JBA's, but I also read enough about them to get the O2 extenders at the same time prior to installation. No CEL's except that there was an exhaust leak where the headers met the mids on the passenger side due to the sub-par gaskets provided with their package. Once better gaskets were installed, that was that.
Here's a pic, very well made, added a good amount of power, and improved the exhaust tone note. Well worth the purchase;
Spec is offline   Reply With Quote
Old 04-23-2015, 12:46 PM   #7
Camarotobeornottobe
Drives: 1LE
Spec, since you seem like a guy who appreciates being prepared, where did you get the "good" gaskets so that someone else might be prepared before HFC purchase?
Camarotobeornottobe is offline   Reply With Quote
Old 04-23-2015, 12:58 PM   #8
Spec
One of my buddy's mechanics was able to procure a couple of steel ones and we replaced the cloth-looking ones JBA provided. When we removed the JBA's, all that was left of them was the wire mesh... the rest of them were completely burned off.
The following thread has a GM Part number to some that could work much better. As you can see, I'm not the only one thinking the supplied gaskets were sub-par.
Here's the GM Part Number:
GM 92202326 | CONVERTER & PIPE GASKET
http://www.gmpartscenter.net/oe-gm/9...FdcegQodtToAoQ
Here's the Link where I found it:
http://www.camaro5.com/forums/showthread.php?t=108147
Old 04-23-2015, 12:59 PM   #9
Spec
Here are some that look good and may work very well with either the Solo's or JBA's... from the same thread above:
http://www.summitracing.com/parts/WLK-31337/
Old 04-23-2015, 01:04 PM   #10
Camarotobeornottobe
Drives: 1LE
So, the GM gasket you link there is the same one that comes with the stock converter new? And it fits on the JBAs just as it would an OEM cat?
Old 04-23-2015, 01:19 PM   #11
Spec
Yep, should fit. Not sure if they're the same ones that come stock, but they'll work better than the JBA's.
Old 04-23-2015, 01:58 PM   #12
Camarotobeornottobe
Drives: 1LE
Thanks much.
Old 04-23-2015, 02:21 PM   #13
AKA-22
AKA-22's Avatar
Drives: ELLE-1
no way !! had them for two plus years code free there are awesome!!!
AKA-22 is offline   Reply With Quote
cats, flow, high, l99, solo
