Old 09-13-2011, 10:37 AM   #1
Hollywood2010
Hollywood2010's Avatar
Drives: 2010 SS/RS
trickle charger
I bought a trickle charger for the camaro over the winter. I've never used one before. I've used battery chargers but that was always for short term. My question is for those of you that have them, do you hook it up in the engine compartment, or do you put it in the trunk. It also has an adapter to charge thru the "cigarette lighter" plug. What do you suggest.
Hollywood2010 is offline   Reply With Quote
Old 09-13-2011, 10:52 AM   #2
NewDivide
NewDivide
NewDivide's Avatar
Drives: SW '13 1SS/RS & '12 Honda CRV
NewDivide is offline   Reply With Quote
Old 09-13-2011, 10:55 AM   #3
Black5thgen
Drives: 2007 C6
I go into the trunk and run the wire through one of the drain plugs. You just pop out a grommet and there is access to the out side. This way I can have my trunk and hood closed and the cover on with out any wires ran under the cover.
Black5thgen is offline   Reply With Quote
Old 09-13-2011, 10:56 AM   #4
Nvincent4708
Drives: N/A
I would say under hood is fine.
As long as it is grounded to the body pin under the hood and the jumper connection (direct wire to the trunk)
It'll be fine.
Or the trunk.
The accessory outlet will not work as our car's outlets are off when the car is.
Nvincent4708 is offline   Reply With Quote
Old 09-13-2011, 12:09 PM   #5
2ndtimess
2ndtimeSS
2ndtimess's Avatar
Drives: 2010 2SS 6 speed Infernal Orange
I used a CTEC all last winter late December thru mid march and no problems. I used the jumper positive under the hood and the ground pin and all was well. Only issue was the time and date were off on the radio, but that has been discussed here before. I also use the charger if the car has been sitting for more than 4 days.
2ndtimess is offline   Reply With Quote
Old 09-13-2011, 04:28 PM   #6
Hollywood2010
Drives: 2010 SS/RS
thanks for the great info.....i think i'm gonna go under hood route.
Old 09-14-2011, 08:44 AM   #7
LT4Lover
LT4Lover
LT4Lover's Avatar
Drives: 2011 SG 2SS/RS,'97 30th Z28 SS LT4
I was wondering the same thing about trickle charging - good info. Just curious, where is the 'grounding body pin' located exactly (i.e. is there one specific spot designed to provide a good ground). I usually just clip the charger to the nearest exposed bolt etc.
LT4Lover is offline   Reply With Quote
Old 09-14-2011, 08:45 AM   #8
Nvincent4708
Drives: N/A
if you look near the jumper connection. you'll see on the right of the car. kinda hidden. this "pin"
that is the ground location.
Old 09-14-2011, 08:49 AM   #9
NewDivide
NewDivide
NewDivide's Avatar
anyone got a pic of that pin everyone's all talking about? 1 more month until hybernation.
Old 09-14-2011, 08:54 AM   #10
Nvincent4708
Drives: N/A
found in this thread
http://www.camaro5.com/forums/showthread.php?t=118771
CTEK Multi US 3300 Battery charger available at www.gmpartshouse.com patrickt Audio / Visual / Electronics/ Gauges / Nav 15 03-02-2012 02:20 AM
Rule The Streets! Magna Charger Camaro ZLs™ BlownChevy Forced Induction - V8 41 02-23-2011 02:40 PM
Schumacher SE-1-12S Automatic Battery Charger / Maintainer Installation PAUL SS Camaro DIY & HOW-TO instructions & discussions 3 11-28-2010 12:53 PM
Battery Trickle Charger Fishdadddy Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 14 10-22-2010 03:41 PM
Trickle Charger Badger Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 16 12-13-2009 12:02 PM
