08-12-2011, 01:23 PM | #1 |
LT4Lover
Drives: 2011 SG 2SS/RS,'97 30th Z28 SS LT4 Join Date: Apr 2010
M6 V8 Owners - Start Off in 1st or 2nd Gear?
Just wondering what everyone with the manual trans V8 (SS) cars are doing as far as what gear they start off with. I have found that the car has enough torque to start off in second pretty comfortably except in heavier traffic where the speed builds too slowly. I am a little concerned about continuing with starting in second though in terms of the clutch since it does seem to mean the clutch is partially engaged for longer while I get going. Starting in first seems to mean shifting too often though and then you often end up with the skip-shift kicking in which is a pain. Any thoughts?
08-12-2011, 01:29 PM | #2 |
Drives: '24 Camaro 2SS Conv. & '21Blazer Join Date: May 2011
I always start out in first from a complete stop. I will start in second if I am creeping in heavy traffic.
'24 Camaro 2SS 6M Convertible
08-12-2011, 01:29 PM | #3 |
TRI-COUNTY CAMARO... FTW!
Drives: 2010 Camaro 2SS M6 Cyber Grey Join Date: May 2010
Just seems to scream burned clutch...... Too heavy a car for starting in 2nd... now if you had 3.73, 4.10, or 4.55's.... thats a whole different ballgame. Just my opinion.
CAI inc. cold air intake, LG G6x3 cam, Patriot Gold Extreme Dual springs, Titanium retainers and locks, LG SuperPro 1 7/8 Long Tube headers with full 3" exhaust, DynoMax VT mufflers, SLP 4" tips, Moroso catch can, Race Ready electronic exhaust cut outs, Full painted Razzi body kit, Headlight Armor Smoke taillight and marker blackouts, T-Rex aluminum upper and lower grille, Polished aluminum front and rear bowties. Professionally installed and Dyno Tuned by HorsePower Sales, Pompano Beach FL.
08-12-2011, 01:34 PM | #4 |
Wild and Cammed
Drives: 2002 Camaro SS Join Date: Jan 2011
NO start in 1st from a stop man lol. If you want your clutch to last start in 1st.
08-12-2011, 01:50 PM | #5 |
Start in first and buy a skip shift eliminator.
08-12-2011, 01:52 PM | #6 |
xbox: this is tedious
I just get up to 19mph then shift. Once you're above that speed skip shift will not engage. In your owners manual it tells you the situations that cause it to turn on and I do my best to never be in those situations.
Big Carrot's Changes - It's a work in progress |
08-12-2011, 01:53 PM | #7 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
08-12-2011, 02:31 PM | #8 |
Camaro Overlord
Drives: 2010 2SS/RS Inferno Orange Metallic Join Date: Jun 2011
Mine always wants me to skip shift. I don't have the eliminator yet. For now, when it tries to do it, I just roll it back to first and THEN into second. It's a PITA. Even when I do get one, I'm not sure how I'll get it installed. To be honest, I'm terrified to get under this car. I'm a big guy and there is NO clearance under it. If it drops, I'm dead.
And to be on-topic: I start out in first unless I'm already rollin' slow. |
08-12-2011, 03:10 PM | #9 | |
Drives: '11 black SS Join Date: Jul 2011
08-12-2011, 03:13 PM | #10 | |
Drives: 2010 Camaro SS Join Date: Jan 2011
Ive never understood what all the fuss is about. Mine tells me to shift into fourth, but still goes into second without any problems what so ever. dont have a skip shift either... is it only the popup screen you guys are trying to get rid of?
2010 camaro 2ss LS3
Corsa catback exhaust w/muffler delete, hennessey intake, Pfadt springs, Hurst Short throw Shifter, Murdered black. GO TEAM LS3 |
08-12-2011, 03:14 PM | #11 |
Drives: 2017 HBM A10 ZL1 Join Date: Feb 2011
Start in first.
Oh yea, skip shift eliminator is cheap and takes all of 5 minutes to install. I bought the guy at a local shop a 6 pack to let me use his lift for a few minutes after he was done for the day. Then we had a beer and talked cars for a while.
My build thread http://www.camaro5.com/forums/showthread.php?t=224342
Go is good. Stop is better. |
08-12-2011, 03:23 PM | #12 |
Sounds like something is very wrong with your electrical stuff or tranny then... because you shouldn't be able to do that without the skip shift eliminator. You sure you don't have it? Like did you buy the camaro used?
08-12-2011, 03:38 PM | #13 |
SoCal Mayhem
Drives: 2010 Camaro 1SS/RS Join Date: Aug 2008
1st
What is the advantage to starting in 2nd?
08-12-2011, 08:21 PM | #14 | |
Drives: 2012 GMC Sierra Z71 4x4 Crew Join Date: Feb 2010
My Chevy dealer quick lube put mine in while they were changing the Mobil1
MBRP 3" CAT BACK, SLP SKIP SHIFT, COLD AIR INDUCTIONS INTAKE, INJEN PRE FILTER,
AAC LED PODS, CUSTOM COACH WORKS PAINT,PFADT LOWERING SPRINGS AND SWAY BARS, MRR HR-6 WHEELS, RPI DESIGNS C-6 HIGH RISE SPOILER(AKA RK SPORT 3 PIECE SPOILER) |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
L99, A6 (1st gear discussion?) | SGOS252382 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 31 | 07-26-2015 10:56 AM |
The 2011+ Mustang Thread | GatorBlue371 | General Automotive + Other Cars Discussion | 11874 | 08-23-2011 12:30 PM |
Does 6L80e drop to 1st gear? | REAPER SS | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 5 | 02-25-2011 04:23 PM |
Clarification Please! L99 and 1st gear | Ace | 5th Gen Camaro SS LS LT General Discussions | 6 | 05-22-2009 03:34 AM |
Will the A6 start off in 2nd gear like the vette??? | TomServo | 5th Gen Camaro SS LS LT General Discussions | 9 | 04-10-2009 09:41 AM |
