Roto-Fab
Old 10-29-2018, 07:24 PM   #15
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
I'm assuming you're getting the car tuned when the headers go on. So have the trans tuned as well, or have the tuner download a stock tune file for the trans.... assuming he/she has one.
CamaroDreams76 is offline   Reply With Quote
Old 10-30-2018, 07:03 AM   #16
Overflow
Space Shuttle Aficionado
Overflow's Avatar
I wasn't planning on getting it tuned with the headers. Was gonna add on a few more parts during the winter and watch how it runs.
Still waiting on the transmission shop to call me...
Overflow is offline   Reply With Quote
Old 10-30-2018, 08:39 AM   #17
WoodBoss
"Old School"
Drives: 2010 2SS L99
Get a JRE dipstick so you can check your fluid level. Most likely it's not low but it's a very basic check you will need to do periodically especially if you mod/tune the car. I have a video of the JRE dipstick install I did on my youtube channel listed below. If you install long tube headers you will need a tune.
WoodBoss is offline   Reply With Quote
Old 10-30-2018, 09:05 AM   #18
qcman
qcman's Avatar
Drives: 2013 Camaro 2SS RDP Tuned L99
I wonder if its something amiss with the TCM but I guess we will see shortly.
qcman is offline   Reply With Quote
Old 10-30-2018, 01:32 PM   #19
UBB
UBB's Avatar
Drives: 2018 ZL1
what was the diagnosis?
UBB is offline   Reply With Quote
Old 10-30-2018, 01:37 PM   #20
Overflow
Overflow's Avatar
So far the shop has driven it three times. No engines codes. No transmission codes. They're going to drive it one more time and look at the hard data from the engine/transmission. Told me it will be done by today.
If they don't find anything, I'm considering going to my local Chevy dealer and seeing if there's a more recent trans software for my car.
Old 10-30-2018, 01:57 PM   #21
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
It sounds to me like it is sensor related. I'm not familiar with the autos but if it shifts fine manually it has to be electronic induced by the means the car uses to determine when to shift
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 10-30-2018, 02:04 PM   #22
UBB
UBB's Avatar
Drives: 2018 ZL1
just have the tranny tuned when you install your LTH and supercharger!
Old 10-30-2018, 02:14 PM   #23
ColdfuzionTN
Drives: 2012 Camaro SS
My 2012 with 17k miles on it did the same thing occasionally then it got to happening more and more. Was a cracked drum burned up clutch packs 4/5/6 common issue in the 6l80e. Hope its not but good luck!
ColdfuzionTN is offline   Reply With Quote
Old 10-30-2018, 02:17 PM   #24
Overflow
Overflow's Avatar
This is frustrating to say the least. This is such a commonly used transmission, but I can't find anything about this happened to someone before.
Hey you! I need to worry about getting my car past 3rd gear before I think about a supercharger!
Old 10-30-2018, 02:24 PM   #25
Overflow
Overflow's Avatar
Oh boy...
I'm assuming this didn't trip a CEL or anything? Also, how'd you end up finding the issue? By pulling the trans?
And if you don't mind me asking, how much did this cost you to fix?
Old 10-30-2018, 02:28 PM   #26
ColdfuzionTN
Yup no codes, paddles worked for the first few months it randomly worked then stopped. Trans shop couldnt find the issue as was working fine when cold. Had to pull trans. Was right at 5k with upgraded components. Hope for you its not but mine was exactly as you described. Good news with the tranny out they gave me a deal on installing dss drive shaft.
Mine was also boosted at that point right around 650 rwhp which attributes to mine but in my reading and freaking out when it happened, that this is a common issue in the 6l80e across models.
Old 10-30-2018, 02:48 PM   #27
Overflow
Overflow's Avatar
Oh no...
So just to clarify, yours would randomly downshift itself too?
Old 10-30-2018, 02:53 PM   #28
ColdfuzionTN
At first it wouldnt, 4th was a real problem but if i got to 5-6 it would be fine. Towards the end I tried manual mode with the paddles. It would down shift with just normal driving and scare the cr@p out of me when it did it.
