TireRack
Old 04-29-2013, 04:12 PM   #1
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Talking Gaining Horsepower By Pulling A Couple Fuses!
If you are new to owning a 2010+ Camaro SS equipped with the L99 or LS3 V8 engine, then you may not be aware of a simple trick that could unleash a few extra horsepower.
There are two specific spark timing tables housed in the memory of the vehicle’s Electronic Control Module (ECM). One is used for cars running high octane fuel and the other for when the vehicle is using low octane fuels. Whenever you drive the vehicle, the ECM is constantly making decisions based on the data it receives from all of the sensors in the engine and exhaust.
The problem:
It seems that if someone puts a low octane fuel into the tank, the vehicle can’t recover from the low octane table. Once in the low octane table the car will continue to use that information even if you are now using a higher octane fuel. Of course the side effect of this is sluggish performance, and we don’t really need to explain the benefits of running a higher octane fuel in a performance application. If you recently purchased your Camaro you wouldn’t be incorrect in thinking that it isn’t uncommon that at some point the car was filled with a less potent gasoline, especially if it came from a used car dealership or from an owner who was uninformed of this problem and wanted to save a few bucks at the pump. The LTFT’s are, unfortunately, a part of the car’s non-volatile memory. That means the information is stored there, and doesn’t reset when the vehicle is turned off.
However, there is a way around this problem. Although the spark tables are part of the non-volatile memory and cannot be removed, they can be reset. A simple solution is to remove a couple of fuses from the fuse block in the engine compartment. Pulling the fuses will allow your Camaro’s ECM to reset itself to the high octane table. If you are running high octane fuel then it remain in the high table until the ECM again detects a low octane fuel.
The fix:
First, make sure the car is empty of the low octane fuel. Run the tank down low and refuel with high octane. You might consider running a tank or two through before attempting the fuse pull. Once you have better gasoline in the system, locate the two fuses shown in the diagram below. They are in the fuse box located on the passenger side of the vehicle’s engine bay. The fuses are in position #5 and #20. Remove each of these 15 amp fuses and allow the car to sit for a period of at least a few hours. There is a small, grey fuse pulling tool located on the fuse panel (In the image below it would be in the lower right corner area). That should make the pulling of the fuses easier. If possible, remove the fuses and allow the car to sit overnight. Once they have been out for several hours, replace the fuses. When started, the car will attempt to use the high octane fuel trims first, and if you keep high octane fuel in the car it should remain on the higher table permanently. Of course, lowered octane fuel in the tank means repeating the process.
Apex Motorsports is offline   Reply With Quote
Old 04-29-2013, 04:18 PM   #2
jbrown13
jbrown13's Avatar
Drives: 2011 Camaro SS L99
Good info Chase. If one has a 93 octane aftermarket tune on his motor does that negate the need to do this?
jbrown13 is offline   Reply With Quote
Old 04-29-2013, 06:00 PM   #3
jim's2ssrs
jim's2ssrs's Avatar
Drives: 2011 2SS RS LS3 Rally Yellow
Didn't IndeedSS1 show that, on an LS3 at least, the ECM reverted back to the high octane table after some time without a fuse pull? I believe this was done back in October/November 2012.
jim's2ssrs is offline   Reply With Quote
Old 04-29-2013, 08:54 PM   #4
11TexaSS
11TexaSS's Avatar
Drives: 2011RedJewel, FI
Sure it's been asked before but here it goes. Does this apply to a car that has been dyno tuned or would the tune already take care of it??
Thanks!
11TexaSS is offline   Reply With Quote
Old 04-29-2013, 08:59 PM   #5
Rhyder
Drives: 2012 45 Anniversary Vert
there's been controversy back and forth on weather it needs to be done or not.
I make my stand on the fact it doesn't hurt anything....pull them and maybe it helps, maybe it doesn't, but your no worse off than you were before and might even be better, and it doesn't cost anything to do, so why not?
Just pull them when you park for the night, then pop them back in in the morning before you leave..... doesn't take but about 5 minutes.
Rhyder is offline   Reply With Quote
Old 04-30-2013, 12:03 AM   #6
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
Thanks!
If you're already tuned don't worry about it. This only applies to the factory calibration.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 04-30-2013, 06:43 AM   #7
11TexaSS
11TexaSS's Avatar
Thanks!
Old 04-30-2013, 01:21 PM   #8
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Thanks!
If your tuner made the lo & hi octane tables the same then it does not matter. Do not put lower octane fuel in it though.
Another 1 of 371 '12 T3 LS3 M6's built.
Iam Broke is offline   Reply With Quote
Old 04-30-2013, 02:39 PM   #9
white20112ss
Drives: white camaro
How much hp gain?
white20112ss is offline   Reply With Quote
Old 05-01-2013, 10:27 PM   #10
theblueSS
theblueSS's Avatar
Drives: midnight blue 2010 m6 ss ls3
just pulled them even though the car has never run on anything but 93 octane under my care but cant hurt to make sure.
theblueSS is offline   Reply With Quote
Old 05-02-2013, 12:10 AM   #11
Muddflap
Muddflap's Avatar
Drives: 2010 Camaro SS
Sent from my iPad using Tapatalk HD
TSP 1 7/8 LT, ADM Race Cold Air w/ Race Scoop, GPI SS3 LS3 Cam, Powerbond UD, 3.91 Gears, GPI Posi Mod.
498RWHP/451RWTQ
Muddflap is offline   Reply With Quote
Old 05-02-2013, 01:22 AM   #12
Sapper12b
HTCC Member
Sapper12b's Avatar
Drives: 2013 Camaro SS
Going to do this tomorrow ...
Sapper12b is offline   Reply With Quote
Old 05-02-2013, 10:43 AM   #13
theblueSS
theblueSS's Avatar
i [put them back in this morning and i feel like i had unleashed more potential from the car. its a bit more responsive and pulls harder. i am happy.
Old 05-02-2013, 08:56 PM   #14
iron_man_status
iron_man_status's Avatar
Drives: Silver Ice Metallic 2SS Camaro
Thanks!! I'm excited my car been feeling sluggish lately
iron_man_status is offline   Reply With Quote
apex, fuse pull, high octane fuel
