Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 07-09-2017, 05:35 PM   #1
Mr V
Mr V's Avatar
Drives: 2011 VR SS Vert
Screw in tire
Well the good news is I found it before driving 12 hours to the fest. I is about 2" in from the side wall. I that far enough it to get it patched? I pulled it out and the screw was pretty short. I soaped it up and can see a small bubble pop about every 30 seconds so I need to patch it. I looked up some posts on the forum and some have said a plug/patch is the best? I don't track the car but was going to try a couple passes on the strip and the camaro cross at the fest. Any advice for me?
Thanks,
Mr V
Mr V is offline   Reply With Quote
Old 07-09-2017, 06:33 PM   #2
Jrichards73
Jrichards73's Avatar
Drives: 2011 2SS/RS Victory Red
2" from the sidewall is fine, take it somewhere that will patch it from the inside and not make a bigger hole to get a plug in it.
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB.
Jrichards73 is offline   Reply With Quote
Old 07-09-2017, 08:34 PM   #3
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
How old are the tires? Had same prob last year on my winter set...put in a plug...zero leak...you patch it gotta pull the tire..patch...remount AND re-balance...$$$$ worth it on a low mileage set...plug it if old and save...takin a plug kit with me just in case....see ya there!!!
btw - ran a couple of 1/4 runs (9!) with this...
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
frankwjr is offline   Reply With Quote
Old 07-14-2017, 06:04 AM   #4
Dan1028
Mechanical Engineer
Dan1028's Avatar
Drives: 2012 IBM Camaro 2SS/RS A6
Are these newish tires with road hazard? Repairs (well, punctures) void most manufacturer speed ratings, if not all for summer tires. If these are newish summer tires and you have road hazard coverage, talk to your tire dealer about replacement. This has happened to me and all I paid for the replacement cost was labor and shop fees (new tire was comp'd).
Current Vehicle: 2012 Chevrolet Camaro SS
Past Vehicle: 2001 Honda Prelude SS
LEFT HAND DRIVE
Dan1028 is offline   Reply With Quote
Old 07-14-2017, 02:24 PM   #5
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I've used those kits with the sticky strip that you push in and then pull out halfway.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
Old 07-14-2017, 02:38 PM   #6
sherob
sherob's Avatar
Drives: 2015 SW 1SS/RS 1LE
Go to Wally World and get this... works everytime like a a charm!
“The Eagles and the Captain and Tennille ruled the airwaves, and we were the answer to it.” - Joey Ramone
http://www.camaro5.com/forums/picture.php?albumid=17325&pictureid=134228
sherob is offline   Reply With Quote
Old 07-14-2017, 03:01 PM   #7
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Plug it - forget all about it. I've done many over the years, never had a problem.
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
