dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 01-22-2015, 02:53 PM   #1
camarossdusk
whippled 5th gen
Drives: 2013 camaro ss
anyone know if stock hurst shifter knob
is threaded, im asking because ordered a line lock for my car and want to use the b&m knob that has line lock button built into it, but its threaded.
Whipple running 13 lbs of boost, Innovators west 8 rib with 10 percent over drive crankshaft pulley. Fore level 2 Dual pump fuel system, with duel TI auto fuel pumps, ID 1300 fuel injectors, tuned on e85. Driveshaft shop aluminum driveshaft, 1400 hp half shafts, Detroit tru-trac. ls9 camshaft, CNC ported heads, with trunion and dual valve spring upgrade, LS9 head gaskets, ARP 2000 head studs, Manley stainless valves. Adjustable Bmr toe rods, trailing arms, rear adjustable sway bar, full cradle bushings, upper control arm bushings, BMR diff. bushings, bmr driveshaft safety loop.
camarossdusk is offline   Reply With Quote
Old 01-25-2015, 06:15 PM   #2
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
The factory OEM Hurst knob is not threaded. 2011-2012 it's push on. The restyled knob for 2013 has a set screw but also does not thread.
You can buy an adapter from Epco that allows you to put a threaded knob on a non-threaded stick.
1968 Camaro Convertible LS1, T56
ckaram is offline   Reply With Quote
Old 01-25-2015, 09:30 PM   #3
camarossdusk
whippled 5th gen
ok thanks been trying to find a way to get a threaded one, are there any aftermarket shifters that have them, also was looking at getting machine shop to make one out of existing stock Hurst shifter, what's recommended.
Old 01-26-2015, 04:26 PM   #4
Whitey 22lr
Whitey 22lr's Avatar
Drives: 2010 SS/RS Black, MT
You may want to think about threading the shifter shaft.
Really a fairly easy thing to do.
http://www.camaro5.com/forums/showthread.php?t=154016
Whitey 22lr is offline   Reply With Quote
Old 02-12-2015, 12:59 PM   #5
Speed2acer
Speed2acer's Avatar
Drives: 2010 2RS/SS Summit White/Inferno
Send a message via Skype™ to Speed2acer
I have a HURST cue ball its threaded. PAy shipping and its yours
Speed2acer is offline   Reply With Quote
