Roto-Fab
Old 09-12-2013, 05:14 AM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
shift light
Im going to make a custom shift light using a rpm activated switch. im thinking of putting it in the center of the gauge cluster below the hi beam light. was wondering if this would be possible. Is there anything in the way? Ill drill a 5/16" hole for a red dash light. What RPM should I set it for? 6000rpm?
Old 09-12-2013, 05:28 AM   #2
AdamZ
Drives: Eve - 2011 Camaro 2SS/RS
6100 (or 6000 if you have a bad reaction time)...you want to leave a little time for yourself to react to the light to make the perfect 6200 rpm shift
AdamZ is offline   Reply With Quote
Old 09-12-2013, 07:57 AM   #3
Fraxum
Fraxum's Avatar
MSD on the dash?
