07-21-2022, 10:44 AM | #337 | ||
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
I don't know why they would allow the valves to be open 30% in stealth, but I do notice that mine doesn't fully close up and allows some exhaust to escape out of the "loud" side. If you have an aftermarket exhaust it almost seems like tuning of the NPP valves is almost mandatory in order to really make the most out of your setup and to have complete control over the way the valves behave which seems to me that GM tuned with sort of funky.
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% Pulley, NGK HR7 Ruthenium spark plugs, Katech Oil Pump, LME tensioner, DOD delete, Cam, MPI lid, Soler ported 87mm (91mm effective) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, Borla X pipe, AFe NPP exhaust, Black Widow Angry Housewife/ Venom 250 mufflers, BMR engine mounts, Banks iDash, Lithium Battery, Course Motorsports phone mount, AEM X- Series, HP Tuners, JMS, E85, 13.6 psi
737 HP/ 779 TQ |
09-28-2022, 07:40 PM | #338 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Was this still loud even in touring or stealth mode? I thought that was the point of having the exhaust valves to control the sound level. |
09-28-2022, 08:00 PM | #339 | |
Drives: 2019 ZL1 Join Date: Mar 2019
There’s quite a bit of decibel difference between open and closed in both cases. The problem wasn’t with the valves, Just removing the cats it was just too loud. High pitched and raspy too. I would say on stealth it was tolerable, but any throttle when valves are open you can hear me a mile away. It’s just too much with headers no cats, full 3” exhaust and an aggressive muffler. Some guys like it obnoxious like that, I’m Over that. My car is still loud but at lower rpm’s and throttle it’s much more tolerable. Honestly having the cats is pretty much like adding decent resonators like the mbrp ones, changes the tone and lowers decibels a bit. I actually added them when I had no choice after blowing 3 cats but removed them after adding the gen 2’s because I thought it got too quiet
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
09-28-2022, 08:51 PM | #340 | |
11-06-2022, 06:00 PM | #341 |
Drives: 18 zl1 garnet red Join Date: Aug 2021
25 pages and finally got an idea of what route to go with, I'll be going with the JonesMF2469, using Amazon as Zoh6 did. My exhaust option is probably different than most around... Stock headers, New Era Cat delete (all4), Speed engineering X pipe into a Corsa sport axle back. The speed engineering Xpipe has the x right in the middle so I'm guessing the MF will take the place of the current X. Will get it welded in hopefully before too long.
After the cats were deleted and SE xpipe installed....First start up and it barked loud and very aggressive. On the first drive it was somewhat enjoyable scaring the shit out of people but I got in the car the second time and I found myself barely touching the gas so it wasn't obnoxiously loud. I'll try and get a before and after video of the difference in sound. Good thread and lots of useful info in here.
IG - @zl1_will
2022 zl1 740hp / 730tq stolen 2018 zl1 Maggie - 2" headers - flex fuel - lowside fuel ssytem - +30 injectors - cordes ice tank - spl rear linkage arms |
11-07-2022, 02:16 PM | #342 |
In case you missed this...search Amazon for "Jones Exhaust 5X8OVAL18 MUF24 OVRALL"
then select more buying choices (62.34). Be sure to select the one from Verocious Motorsports. According to the prior posts, these guys have the correct one.
11-07-2022, 03:24 PM | #343 |
I used the link you posted as a matter of fact. I then asked around some more and found some Kooks Green cats that I'm picking up. Thanks Grampa
IG - @zl1_will
11-07-2022, 07:05 PM | #344 |
Drives: 2018 Camaro ZL1 Join Date: Nov 2009
Please post up sounds clips and videos planning on going with some headers and intake in December
2018 ZL1 M6 NGM
PPF and Ceramic coating IG: NGMZL1 2010 2SS RS --- SOLD MODS- Performance: BMR trailing arms & bushings | BMR Toe links | X-pipe | Muffler delete | Vmax ported throttle body | Apex "strong" MAS | Vararam CAI | Apex catch can | Kooks Headers | Kooks HF Cats | Dyno tuned by GPI 417 RWHP 409 FT-Lb Cosmetic: painted Zl1 rockers | Zl1 grill | AAC side markers | AAC LED backup lights | windows tint | taillight tint | JDP tow hook | all emblems blacked out | LED fogs |
11-08-2022, 04:58 AM | #345 |
Will do, if you check my Instagram, you’ll see a few videos of startup videos of the current Catless setup. I should have the kooks installed by Thursday and will update the thread
IG - @zl1_will
11-08-2022, 05:31 AM | #346 |
You will still have a deep throaty tone with the Kooks cats, but it won't have any of the nasty resonance that you get with a catless setup and of course no more stink.
11-08-2022, 09:50 AM | #347 | |
Drives: 18 ZL1 - M6 Join Date: Mar 2019
Did you ever get a chance to do some before and after sound clips? If so, would you mind throwing them up so we can hear what that Jones system sounds like compared to the magna flow? Thanks brother |
11-08-2022, 10:07 AM | #348 |
I did not do a before and after but I can tell you I was not happy with the sound after the Jones muffler install. I was actually happier with the previous Magnaflow muffler even though it was probably more restrictive. It still sounded raspy and "sloppy" is the best description I can give you with the Jones muffler installed. I really really hated it. I've come to the conclusion that these cars just don't sound that good with cats removed so I went back to a high flow cat setup. High flow cats really clean up the exhaust tone, remove the raspyness and obviously get rid of the obnoxious fumes. I will not pursue running this car without the cats anymore unless it was a 100% drag car. It costs more to use a high flow cat setup but the benefits are worth it to me. My exhaust guy teases me because I tried so many different combinations of mufflers and resonators trying to make it sound right without the cats. I gave up.
11-08-2022, 10:49 AM | #349 |
S*#T!!!! I just ordered the Jones X today. But, after reading through your post, it’s got me thinking that I need to cancel it. In any case, did you end up keeping the Jones muffler after adding the high flow cats back to your set up? If so, would you mind throwing a sound clip up of how it sounds now? Thanks bro
11-08-2022, 11:43 AM | #350 | |
