06-15-2021, 12:28 PM | #1 |
Drives: '12 Camaro 2SS/RS Vert Join Date: Oct 2020
MRR017 Tire Size Recommendations
Decisions decision... I've pretty much decided on MRR017 wheels gunmetal in 20x10 front and 20x11 rear. My current rear 275/40 tires are newish and I was planning to put them on the front and buy a new set of 315/35s for the rear. However, I'm also considering the ZL1 setup with 285/35 front and 305/35 rear. The car is mostly a good weather cruiser and I'm looking for a good balance of ride/handling and looks/stance. Any opinions out there on these tire sizes? Pros and cons? Here are current pics of the car with stock wheels and lowered.
2012 Camaro SS Convertible: 2SS, LS3, M6, Triple Black. Mods: Solo Axleback, 1LE FE6 rear swaybar, CAGS delete, Vararam CAI, Heritage grill, Hotchkis springs, '15 FE4 struts/shocks, ZL1 side rockers, Velgen Classic5 wheels, Pedders radius rod bushings, ARH LTHs, gutted HFCs,...
06-15-2021, 12:32 PM | #2 |
i run the 275/40 in the front with the 305/35 in the rear
2014 2SS/RS VERT L99 SUMMIT WHITE AIRAID CAI BORLA ATAK CAT-BACK EXHAUST ELITE ENGINEERING CATCH-CAN RANGE AFM-DELETE MODULE HUPER OPTIK 40 CHROME PEDALS PREMIUM FLOOR MATS PREMIUM CARGO MAT DEDICATED 32GB iPHONE HD[/I][/B][IMG][/IMG] |
06-15-2021, 12:38 PM | #3 |
Nice! You've split my options! What tires are you running?
06-15-2021, 01:55 PM | #4 |
Drives: 2010 2SS/RS, VR ext/Blk Int Join Date: Jul 2012
I have 275/40 fronts and 315/35 rears, Nitto 555G2s. No issues.
06-15-2021, 02:04 PM | #5 |
Thanks glad you responded. I was going to ask you in your diffuser thread your tire sizes.
06-15-2021, 04:23 PM | #6 |
The only issue I had which is common for 2010 and 11 models is the passenger side e-brake cable rubbing on the wheel barrel. Looked like plenty of clearance when I put the wheels on but touches when the suspension moves apparently.
06-15-2021, 05:14 PM | #7 |
Drives: Camaro SS Join Date: Feb 2014
I’ll be getting my M017 on Friday in gloss black.
I’ll put my stock 275 PZeros in the front and in the rear I will run nitros 555G2 at 305 I wanted to save a few dollars and run the stock tires up front. Sent from my iPhone using Tapatalk |
06-15-2021, 06:26 PM | #8 |
Hmmm I’ll have to look out for that.
06-15-2021, 06:28 PM | #9 |
Please post picks! That’s what I was planning to do with the stock rears until I got this crazy idea to change tire sizes up front.
06-15-2021, 06:43 PM | #10 |
I as well as others on here just tie the ebrake cable back so it doesn't rub the wheel.
06-15-2021, 07:23 PM | #11 |
I have the M228's on my Camaro which are the same width and offsets as the ones you are getting and I run 275/35/20 front and 315/35/20 rears and am lowered 1.25
06-16-2021, 09:09 AM | #12 |
Thanks guys! I'm leaning more towards the 315/20s with the 275s up front.
06-16-2021, 11:17 AM | #13 |
Pirellis P Zero's
06-19-2021, 07:13 PM | #14 |
