Old 11-30-2019, 07:59 AM   #15
Bilicki66
Drives: 2018 Camaro 2SS 1LE
Originally Posted by gdgraph View Post
Someone asked for a summary of how to do the wire harness relocation for the driver side rear wheel well when upgrading to larger tires. I uploaded this summary and picture and figured I would share here:
Here's a picture of my driver side rear wheel well. After you remove the wheel well liner you should see a cable that runs in the general path of the red line.
- Remove the wheel well liner by popping out the handful of plastic clips (I only undid the forward half of the liner)
- The yellow marks represent where the cable is secured with a zip tie,
- Cut the bottom 2 that are shown
- Relocate the cable by sliding it inboard as far as it goes (shown by the green line)
- Down at the bottom by the harness connector you will see a frame with a hole that you can run a zip tie through to secure it in it's new location
You can see in the picture where the hole will form from rubbing. This particular picture is from a BFG 305/35/20 on stock springs. Why did I go with a 35 instead of a 30... Because that's all the BFG comp 2 A/S comes in and I wanted to run a 305 size A/S on my 20x11s.
After a few hundred miles the rubbing stopped (didn't get any bigger than what you see below) and no issues with damage to the cable.
Thank you for this great schematic, I am going to Toyo RR tires for the road course which is a 315/30 for my stock 2SS 1LE rims.
Also, do you have to do both sides or just one?
Last edited by Bilicki66; 11-30-2019 at 08:00 AM. Reason: Didn’t write all I wanted
Bilicki66 is offline   Reply With Quote
Old 03-19-2020, 06:59 PM   #16
GTO_Gregory
GTO_Gregory's Avatar
Drives: 2016 Camaro
I've heard that after you relocate the wire, using a heat gun to reshape the fiber wheel well liner can help.
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff.
2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85.
GTO_Gregory is offline   Reply With Quote
Old 03-20-2020, 03:19 AM   #17
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
Originally Posted by Gatorac View Post
I'm gonna say no because mine is wearing through the liner right at that spot and i't completely stock.
my early 17 SS with 1LE suspension and ZL1 wheels 305/30/20 and not a scuff on the liner.
Old 03-21-2020, 10:55 AM   #18
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
All I did was use one of those panel fasteners, drill a small hole in the wheel liner in the area that protrudes out, and push the clip through the liner into a hole on the chassis(I used a hole where the wire harness was zip tied prior to relocation). It holds securely and looks like OEM with no clearance issues or rubbing.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 05-13-2020, 12:51 PM   #19
tony19118
tony19118's Avatar
Drives: 2016 Camaro 1SS M6 Hyper Blue
Send a message via AIM to tony19118
Damn. I wish I had known about this yesterday.
2016 1SS M6 Hyper Blue - Owned 2020-present
2012 1LS M6 Black - Owned 2015-2020
1995 Z/28 M6 Green - Owned 2011-2015
1999 V6 A4 Red w/T-Tops - Owned 2002-2008
tony19118 is offline   Reply With Quote
Old 05-13-2020, 01:21 PM   #20
H(.)(.)ters
H(.)(.)ters's Avatar
Drives: 2SS - Black
What tires and size?
Procharger D1X
Kinda fast, I guess
H(.)(.)ters is offline   Reply With Quote
Old 05-13-2020, 06:35 PM   #21
tony19118
tony19118's Avatar
I put on a 295/40r20, a tire that my buddy is very successfully running on the back of his 5th gen SS. We didn't think the size of the fender well would be that huge of a difference. We thought wrong.
Anyway, I had the tire shop put my old bald Goodyear Eagle F1s back on yesterday after I heard the rubbing. The damage was already done tho, and the check engine light was on. Just waiting for the other tires I ordered arrive at the shop. Got the wiring harness repaired today too, so no more CEL for now.
Old 11-17-2022, 06:33 PM   #22
Camaroking98
Drives: 2019 ZL1
Think this would be necessary for the ZL1 with 325 30 R20?
Camaroking98 is offline   Reply With Quote
Old 11-17-2022, 09:53 PM   #23
From what I read, gm changed the routing of this body harness at some point, not sure if it was 2019 or 2020, though, meaning you may get away with not touching the harness. I'd check no matter what.
This tire is 0.8" wider than stock, so you may need a small spacer and/or massage the wheel well liner with a heat gun, because there isn't a lot of clearance to begin with, harness or not.
Also, the 11" wide stock rear wheel is fairly narrow for a 325 width tire, the ZL1 1LE has 12" wheels in the back.
Old 11-17-2022, 10:20 PM   #24
Camaroking98
Drives: 2019 ZL1
guess I'll find out tomorrow...I sent the shop some of these forum posts and a video on youtube explaining the harness thing if they run into it. I saw that 325's were the widest tire available so that's the one I went with lmao.
Old 03-28-2024, 02:43 PM   #25
havelegs
havelegs's Avatar
Drives: '23 LT1 A10
I'm going to have MRR M017 20x11 wheels and run 305/30/20 in the rear on my '24 LT1, is the harness location needed?
24 LT1 M6 Sharkskin Metallic
havelegs is offline   Reply With Quote
Old 03-28-2024, 10:03 PM   #26
No, you'll be fine. This is a standard SS 1LE / ZL1 tire size, the wheel well and the main body wire harness are clearanced to accommodate it. I think the offset of those MRRs is within a few mm of stock, not enough of a difference to interfere with anything.
If you want to do additional research, here is a great site to start with: https://wheel-size.com
Old 03-29-2024, 05:51 PM   #27
havelegs
havelegs's Avatar
Drives: '23 LT1 A10
Thanks buddy
Old 03-29-2024, 11:37 PM   #28
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Thanks buddy
I put the same wheels/tires on my 2020 2SS, I didn't need to relocate the harness but decided to just as a precaution, super easy to do...
Here are some before and after shots:
Before:
After:
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires
Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph...
