02-12-2016, 12:20 AM | #1 |
Drives: 2011 2SS/RS (M6) 427 Twin Turbo Join Date: May 2008
Issues with my Twin Turbo Setup - Please advise!!
I have a 2011 SS with the agp twin turbo setup. i have a few issues that i could use some advisement on.
1. The catch can is spitting oil all over itself everytime i drive it and it seems like it happens every time i give it some gas not just when i get into boost. i lost about a 1/2 quart in only 1-2k miles. 2. the oil smells burnt even just checking the level on the dip stick you get a whiff of the burnt smell. 3. im noticing a ticking noise under the hood. i could just be paranoid but it doesn't seem normal. im worried it might be something major like signs of engine failure. any ideas of what could be the issue? thanks!
2011 Camaro 2SS/RS ERL 427 M6 TT -AGP Twin Turbo 55/57 .83ar | ERL 427ci | Squash Fuel System | Stainless Works Chambered 3" | Mcleod RXT | Factory Hurst Short Throw | Black Forgestar F14s | CTS V 6 Piston Brembo | VIS AMS Carbon Fiber Hood | Anvil Carbon Fiber Spoiler |
02-12-2016, 12:38 AM | #2 |
I think you blew your engine man, i experienced the same things when I had a Agp kit. Turned out I blew piston #4 and 7.
13' Camaro SS 746WHP
LSA Supercharged, Built 416 Stroker, BTR Stage III Pd cam, M6, Corsa Exhaust, DMH Cutouts, Vip Modular Wheels, DSE Suspension, Squash Fuel System. |
02-12-2016, 07:50 AM | #3 | |
Drives: 2014 1LE, 1996 z28 Join Date: May 2015
02-12-2016, 08:02 AM | #4 |
Drives: 2012 SS Join Date: Sep 2012
I had oil constantly oozing out of my agp catch can. Did a leak down and compression test and every thing was fine. Turned out that my Holley valve covers have shitty baffling and that was the issue.
02-12-2016, 08:04 AM | #5 |
Drives: 2013 Camaro SS Coupe L99 Join Date: Feb 2013
Compression test will show if you hurt a cylinder or two. Any data logs from just before you noticed this issue?
02-12-2016, 08:05 AM | #6 |
Drives: 2006 Z06 Join Date: Oct 2010
Post how the catch can is setup. Valve covers?
Compression/leak down check. LS motors tick, so without more info hard to say anything there. Doesn't sound like anything is related to the turbo setup, but possible a motor or plumbing of the catchcan issue.
Nick
Corvette Z06 -1200ish rwhp |
02-12-2016, 08:54 AM | #7 |
Drives: Silver SS/RS, Man 6 Join Date: Apr 2009
Sounds like you are pressurizing your catch can under boost. So, you need a check valve to check against the pressure but not against vacuum. Hope the ticking etc works out. Compression check for sure.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers, GM 3.91 Rear Gears |
02-12-2016, 10:06 AM | #8 |
As per our phone conversation, When you changed your boost controller set up you added 3 psi boost at the top without re-tuning, and it is possible you detonated the engine.
Your tune was optimized for your boost curve 12 sloping down to 9. when you change the boost curve to 12 flat the car needs to be re-tuned for that boost curve. A leak down test is in order to determine if you broke a ring land. I will look over your catch can set up when you send the pics. Ted.
www.jannettyracing.com
02-12-2016, 10:12 AM | #9 |
Adding 3psi without tuning is a bad idea. That could be an easy 100+rwhp more.
Nick
02-12-2016, 10:50 AM | #10 |
Drives: 2011ShelbyGT500 Join Date: Jan 2014
02-12-2016, 10:55 AM | #11 | |
30 is on the low end.
Nick
02-12-2016, 11:00 AM | #12 |
02-12-2016, 11:42 AM | #13 |
Just one of many results but for reference
Stock LS3 (for now) Stock Clutch (yeah, for now) Stock rear (again, for now) Nightfury 113LSA Squash Fuel System E85 Flex Fuel (dyno with 80% ethanol) 1000cc injectors Larger intercooler Journal bearing 55/57 .63 ar turbos. 625 hp @ 6lbs 700 @ 8lbs 845 @ 12lbs So ~36rwhp per lb of boost.
Nick
02-12-2016, 11:48 AM | #14 |
Drives: 2012 CTS-V, 2010 Camaro SS Join Date: Sep 2013
So you upped boost and didn't retune? Sorry man probably hurt something.
2012 CTS-V: Cosmetic Chute. |
