dave@hennessey
Old 01-13-2016, 12:51 PM   #1
forklord
forklord's Avatar
Drives: 2010 2SS
who makes aem sensors???
Speed shop lost my boost guages sensor and is fickin around. Its 100 can$ on summit. I know arm dont manufacture it. Wondering if i can get it cheaper somewhere. Bit of a strech probly but i figured id try. Thanks guys
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 01-13-2016, 03:29 PM   #2
badass1000
Drives: 2010 SS. YSI and Built 416
Depends on what sensor. post a pic or part number. I know some of their sensors are made by:
http://www.ssi-sensors.com/
they are great sensors. Last time I needed some for my ams2000 on my hayabusa I believe the cheapest I found them was holley.
I don't know what sensor you have and different sensors give 0-5v voltages for different pressures.
And around $100 is a good deal for a SSI sensor. Not going to find them much cheaper then that.
badass1000 is offline   Reply With Quote
Old 01-13-2016, 10:16 PM   #3
forklord
forklord's Avatar
Drives: 2010 2SS
30-2131-50
Old 01-13-2016, 11:04 PM   #4
jasycz28
J.Sick
jasycz28's Avatar
Drives: 2010 Camaro SS
http://www.amazon.com/AEM-30-2131-50...rds=30-2131-50
"J.Sick"
2010 Camaro 2SS
jasycz28 is offline   Reply With Quote
