Old 05-17-2015, 03:17 PM   #1
ender2664
Drives: 2016 2SS
gas mileage
I know most people do not buy camaros for their great mpg, and I am no exception to the rule. But I do drive my car more than 2k-2.5k miles a month, so mpg does factor into my cost calculations.
that being said, I currently get 33mpg on the freeway. Given the weight loss, aero improvements and more efficient motor, do u believe that 35-36mpg is a realistic expectation?
what do v8 guys currently get on the freeway? Not claimed, but actual? 26?
ender2664 is offline   Reply With Quote
Old 05-17-2015, 03:22 PM   #2
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
I can get 27-28 on the hwy pretty easy with my 10 SS manual.
I am curious how these will perform mpg wise in the real world
Old 05-17-2015, 03:34 PM   #3
ALLTRBO
ALLTRBO's Avatar
Drives: V8 up front and 7-spd out back FTW
In my 2012 SS manual I got about 22 mpg highway average around 70-75 mph on a cross country trip (measured and calculated the old-fashioned way, though the DIC was almost spot-on).
For about 10 miles, though, I carefully drafted a semi in a one-lane construction zone at 55 mph and the DIC registered 33 mpg for that 10 miles.
Commuting on highway I got about 20 mpg average due to heavier and inconsistent traffic.
I would expect the manual LT1 6th gen to get around 25 mpg highway for most people, plus or minus a few depending on conditions. Add a couple to the 8-speed with its useful and honed-in AFM (unlike the L99's AFM which was also in a bigger and heavier car).
I think both the V6 and turbo 4 will get outstanding highway mileage, especially the V6 auto on a flat highway (due to AFM). Wouldn't be surprised to see people posting near 40 in perfect conditions.
Those are my predictions, anyway. Time will tell. As always, YMMV.
ALLTRBO is offline   Reply With Quote
Old 05-17-2015, 03:49 PM   #4
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
The 0.50:1 6th gear (vs. 0.57:1) + lower weight + better aero (from 5th gen) should help get respectable fuel economy on the highway. The manual Vette is rated at 17/29. I'd expect the manual LT1 camaro to be around 16/28 or within 1mpg of that on the EPA tests.
I'm surprised you're able to get as high as 33mpg. Is this an actual measured # or what the ECM is estimating?
Old 05-17-2015, 03:50 PM   #5
vtirocz
vtirocz's Avatar
Old 05-17-2015, 04:01 PM   #6
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
LOL Road and Track just got 13 mpg with the Mustang Ecoboost 4cyl in the current issue's comparison test.
wakespeak is offline   Reply With Quote
Old 05-17-2015, 04:05 PM   #7
ChefBorOzzy
ChefBorOzzy's Avatar
Drives: 2016 F150
Doesn't the LT1 in the Vette with the manual have AFM as well? According to GM, not available on the manual in Camaro.
ChefBorOzzy is offline   Reply With Quote
Old 05-17-2015, 04:24 PM   #8
ALLTRBO
ALLTRBO's Avatar
Correct.
It works amazingly well for me in my C7 manual (but I can turn it off if I want). Given that, I'm not sure why it's not on the 6thgen LT1 manual.
Old 05-17-2015, 05:08 PM   #9
ender2664
Drives: 2016 2SS
2 times a week I drive the same 130 mile trip. Worst mpg has been 31 best has been 34. Speed limit veries but I usually average 71.
I usually just have the computer calculate it, but check occasionally by hand to make sure it is not lying to me.
I was under the impression that no company uses afm on manual cars :/ I guess from this current discussion I am incorrect.
But neither the V6 or v8 manual camaro will be offered with afm, correct?
Old 05-17-2015, 06:04 PM   #10
ALLTRBO
ALLTRBO's Avatar
Right... According to the info that has been released, no manual trans 2016 Camaro will have AFM. Both the V8 and the V6 automatics will have it.
Old 05-17-2015, 06:29 PM   #11
mt3130
Drives: Coupeless :(
I've stated my (unpopular) opinion before: I would like to be able to average 22-23 mpg in the SS.
My commute lends itself to good gas mileage, so I think its doable. 16-17 city and 27-28 highway would be a sure fire way to get me into one.
mt3130 is offline   Reply With Quote
Old 05-17-2015, 09:35 PM   #12
RenegadeXR
RenegadeXR's Avatar
Drives: 2011 Camaro SS
2011 automatic SS. I get about 22-23 mpg highway, but that's after losing a bit due to wider ZL1 / 1LE tires that have higher rolling resistance and some cosmetic mods that ultimately could affect drag. City is about 15 mpg, but only because the throttle gets thrashed a lot between lights.
Nobody will be able to say what the mpg of the 2016 will be until it's driven under real world conditions. The EPA figures are bogus, especially for anything with a turbo, since activation of a turbo increases fuel consumption and the tests are generally carried out when it isn't active.
RenegadeXR is offline   Reply With Quote
Old 05-18-2015, 06:05 AM   #13
Chevy_cowboy
Chevy_cowboy's Avatar
Drives: 2011 IOM 2SS/RS M6 Convertible
Sure its doable, I drive mine hard most of the time and average nearly 20, 15% better would be easy if you drove for mpg.
Chevy_cowboy is offline   Reply With Quote
Old 05-18-2015, 11:17 AM   #14
Norseman
Drives: 2010 SS - CGM
I have a 100 mile (one way) commute twice a week, 20% city, 80% highway, and I average 22 MPG in my 10SS Auto. In town I tend to smash the throttle, but once the cruise is set I tend to leave it.
So yes, 22 MPG on the SS is *VERY* do-able!
Norseman is offline   Reply With Quote
