TireRack
Old 05-23-2019, 01:25 PM   #1
rozarioorlan
rozarioorlan's Avatar
Drives: 2013 Camaro 2LS
Nitto NT555 G2 vs Motivo
Looking at a set of wheels and tires and for the same price can get either the NT555 G2 or Motivo. Which do you prefer or recommend? I currently have the NT05 but the wet handling is terrible and pretty scary.
Sizes are 275/40/20 and 315/35/20. Used for daily driving only, maybe have about 20-30 rainy days a year so it should be good for both dry and wet driving. No drag strip or track racing.
2013 2LS - K&N CAI, Overkill Ported 80mm Throttle Body, Overkill E85 Kit and Overkill Tune, Jacfab Ported Intake Manifold and Spacer, Stealth 3.0 TC, ARH Catted Downpipes, Magnaflow Resonated X-Pipe, Resonator Delete, Jones Full Boar Racing Mufflers, BMR 1.2" Lowering Springs, Elite Engineering Catch Can and Clean Side Seperator
rozarioorlan is offline   Reply With Quote
Old 05-23-2019, 01:50 PM   #2
BAD DAB
BAD DAB's Avatar
The Motivo is more of a All Season tire.
Old 05-23-2019, 02:23 PM   #3
PepeLePew
PepeLePew's Avatar
Drives: 2010 2SS Coupe; 2011 2LT Vert
I had the motivos on my SS and they were great. Both are great street tires and you'll be fine with either. Since you have the 2LS, I'd probably save a little money and go with the motivos unless you want to spend a little more for the more aggressive tread pattern.
Or if you really want to save some money AND get a great tread pattern and performance, you should look into the Atturo AZ850. The 275s run about $105 each and the 315s are about $135 each. I would run these tires on mine but they don't sell a 245/45 20. Check on the many long term reviews on Youtube and Amazon.
2010 2SS/RS LS3 - K&N, GM Performance Axle Back, Hurst Shifter, TSP 1 7/8ths long tubes no cats, TSP Stage 2 "Bald Eagle" cam, GM 3.91, 466whp/429tq
PepeLePew is offline   Reply With Quote
Old 05-23-2019, 02:30 PM   #4
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
Good luck with your choice. I've heard a lot of good things about Nitto 555G2's and will be going with them on my next tire setup.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 05-23-2019, 03:39 PM   #5
Joecruiser
Joecruiser's Avatar
Drives: 2014 2-SSRS Slushbox
I’m running Nitto G2s because that’s what the PO installed.
Like a space cadet, I bought new tires PRIOR to becoming familiar with the Gen 5 and bought the wrong size! Do’h!
Im getting ready to bite the bullet and go 275 and 305.
I’m happy with the G2s although you do have to use caution when wet.
Needless to say, I’m not happy with the “stance”
Joecruiser is offline   Reply With Quote
Old 05-23-2019, 06:37 PM   #6
Roader
Drives: Camaro
Just installed G2s and they were the “same size” as my Toyos but we’re actuslly wider. Make sure they’ll fit if lowered at all. First bump the tire caught the fender
Roader is offline   Reply With Quote
Old 05-23-2019, 07:09 PM   #7
Sinister10
Sinister10's Avatar
Drives: 2010 Camaro SS
i have the Motivos in the sizes you are getting. I have no complaints this far, good traction wet or dry, no road noise. They do smoke pretty good ..lol
2010 2SS/RS 6M, MGW flatstick, CAI cold air intake, SLP loudmouth 2 axleback, TSP 1 7/8 headers w/ hfc, pfadt 1" springs, SRP pedals, emblempros "6.2L" emblems on hood, ZL1 grill, M/T SC-5 wheels, nitto motivo 275f 315r. ZL1 addons wickerbill, smoked lenses, resonator delete x pipe, diode dynamics DRLs 1LE suede steering wheel, mighty mouse CC. SCTX4 and Dyno Steve tune.
Sinister10 is offline   Reply With Quote
Old 05-23-2019, 07:47 PM   #8
Welker2
Ret AF, cancer survivor
Welker2's Avatar
Drives: 2013 Camaro 2SS/RS & 2006 Corvette
I also have the Motivos and really like the ride and handling characteristics, even in the rain. Will be buying them again when the time comes.
Welker2 is offline   Reply With Quote
Old 05-23-2019, 08:21 PM   #9
Spec
Drives: 2010 Camaro 1SS LS3
For the foreseeable future, G2's will be what this car lives with. These tires are great, hook up very nicely on 315's, and also have an agressive aesthetic look. Thoroughly satisfied with them.
Spec is offline   Reply With Quote
Old 05-26-2019, 02:01 AM   #10
DagoCountyGee
DagoCountyGee's Avatar
Drives: '15 SS
Just installed G2s and im happy with them.
Follow My Car on INSTAGRAMhttp://www.instagram.com/forb1dd3n_ss
DagoCountyGee is offline   Reply With Quote
Old 05-26-2019, 05:40 AM   #11
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
If you want traction and grip try the Nitto 555R's. Excellent wet manners and great dry launches.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 05-26-2019, 06:35 PM   #12
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
I have the Motivos now with factory sizes (245/45 and 275/40). They are a decent street tire but I'm not impressed with performance driving. They spin easy with moderate throttle and the sidewalls flex in hard corners. I came from the factory Pirellis and there was an immediate difference in body roll (advantage to Pirellis). When my Motivos are done, I think I'll try the 555 G2's.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
