Old 01-16-2014, 10:10 PM   #15
Keenov
Drives: None ATM
Originally Posted by toehead93 View Post
What year was the last time GM did this? 2001 with a 25hp difference. That was 13 years ago. The 2002 Vette had the new LS2 and the 2002 SS had the old LS1 so they don't count. Of course the Camaro was gone until 2010 but that doesn't help- my case so I'll stop here.
The Corvette didn't get a LS2 engine until the C6 came out, 2005 model year. But yea it's been awhile!
Keenov is offline   Reply With Quote
Old 01-17-2014, 11:18 PM   #16
2012-1822
2012-1822's Avatar
Drives: Black ZL1
Originally Posted by Bhobbs View Post
I think if GM can get the weight down enough on the 6th gen and doesn't water down the power on the LT1 to keep Vette guys happy, they have the chance to outclass the Mustang in both the 1/4 mile and around a track. GM has a huge opportunity and I expect them to take full advantage of it.
I feel like GM learned their lesson on the weight difference between the current Muffstain and Camaro. We know ford is stepping up handling on the new Stain, so I think that the new Camaro will be lighter indeed. I hope, really hope, that it's lighter than the Muffstain. But as Fbodfather has pointed out, Muffstain is ford's Camaro and Corvette, so they can go wide open on it.
Either way, from a performance stand point, I think the 6th gen Camaro is going to be completely bada$$.
Check out Alabama Camaros, for Camaro enthusiasts all around Alabama https://www.facebook.com/groups/1739...group_activity
2012-1822 is offline   Reply With Quote
Old 02-15-2014, 02:39 PM   #17
S3XPanther
by Odeon
S3XPanther's Avatar
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM
I personally like the new mustang very much, more so from a styling standpoint than anything else. I'm sure the performance will be killer, but not better than the next gen Camaro. The new LT series motors are outstanding (except for DI which I HATE), and I don't feel Ford's improved Roadrunner-based 5.0 can outperform an LT1 Camaro SS or hi-po LT4 based model. And, as far as chassis are concerned, both will sport vastly improved platforms.
With that said, however, I'm truly concerned with the styling design direction the next gen Camaro may take. I love the 5thgen (pre-2014 only) because it was basically a modern interpretation of the 1st gen. I just don't feel the new design can be as big of a home run as the 5thgen, imo.
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time."
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy."
2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's)
S3XPanther is offline   Reply With Quote
Old 02-16-2014, 04:39 PM   #18
toehead93
Drives: 2014 2SS/1LE
I don't see it as GM learning their lesson. GM had no choice but to use the chasis the Camaro is on as it was the only chasis available for the Camaro at the time. It was either go with a heavy Camaro or no Camaro at all. They knew going into it that weight was an issue and dealt with as best as they could. Now both Mustang and Camaro will be on level playing fields...the mustang with IRS and the Camaro with less weight.
As for looks, the only thing I don't like about the current Mustang is the rear. Now they took everything I hated about the rear and exaggerated it, so I do not like the rear even more now. Maybe it will look better in person
Used Racing Brake 2 Peice Rotors for sale:
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 02-17-2014, 05:44 AM   #19
ssrs2lt
ssrs2lt's Avatar
Drives: too many
I think GM should build Camaro using same material used in vette. carbon fiber and aluminum frame. lighten the load and apply the best engine. if the Ford comment about horsepower is true, we're in trouble. in the long term everyone will have less power..
Old 02-17-2014, 09:29 AM   #20
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
If Camaros were still produced in 2005, pretty sure it would have been powered by the LS2. There was no more LS1/6 in anything in 05; they swapped a LS2 in all hp/performance application CTS-V/Trailblazer SS/ Vette/SSR/etc. Other engines were truck specific, made of iron.
The Camaro will always be too heavy to outperform the Vette with the same power output.
If GM ever decide to offer 2 V8 engines in the next Camaro, they rather sell the 5.3l version at a really really, really low price, because its going to be embarrassment for the name of the car. I dont see how they could lower the price that much cause they would need to use the same powertrain as the LT1 if they want this setup to be reliable.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
