Hey everyone, I'll be getting my car cammed soon. I was wondering if its worth it getting the ATI pulley as it gets to the shop? The shop is Fast Lane Performance located in ATL, if anyone also knows anything about them and their work.
The cam/heads kit for me includes: King Kong V2 cam/TSP cam of my choosing (shop cam) .660 dual valve springs hardened push rods new valve seals LS7 style lifters gaskets, trays, bolts new spark plugs and taylor spark plug wires tune ported manifold (in house) ported throttle body (in house) ported heads (in house) C7R timing chain Trunnion upgrade I do want an aggressive chop and something drivable, but moreso power and a higher rev range. They did mention I should be able to rev up to 6.8-7k after all of this. They did mention porting of headers (not heads, headers. Exhaust Manifold) said it was some sort of "old school" trick and whatnot. Haven't found enough information to agree to it though. Does anyone know anything at all about this or is it just bs? I want max performance from this and plan on keeping the car NA, boost will be saved for another car. What else can I add to the build? Currently running E85 already. I am open to other mods such as solid rear cradle from the ZL1 1LE and will be asking them on that install as well. Thank you guys! ![]() ![]() |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1SS NFG A8 Join Date: Aug 2017
The Camaro has Tri-y shorty headers from the factory, not manifolds. Long tube headers will make some extra power especially with the primary cats removed(biggest restriction in the exhaust). I would go with a LT2 manifold with a 95mm tb over ported stock. Didn't see anything mentioned far as VVT limiter or lockout kit but I would lock it out.
Far as maintenance, that depends on the specs of the cam(lobe intensity and lift) I would check valve spring pressures every 10-15k miles and plan on changing them every 25-30k miles. Not a big fan of LS7 lifters in higher rpm applications with heavy springs and high lift.
2016 NFG 1SS A8
#3 | |
What kind of lifters would you recommend? A lot of people say Johnson lifters are the way to go, but the shop told me that they're running LS7 lifters on their shop ZL1 making around 850 rwhp which is currently cammed. Last edited by MrNooNoos; 10-26-2020 at 08:39 AM. Reason: more info |
HP is not the limiting factor for lifters it's cam lobe intensity, spring rates, and rpm. Often times NA cams have more aggressive lobe profiles then Supercharged stuff and rev higher. Ask the shop if they are going to put 50k miles on their shop ZL1? Sure it might be making that power and handling it now, but most Shop builds are not built with longevity in mind.
Imo the build you have listed above is a combination that will likely need maintenance in 20-30k miles at best. If you are just going to get the car out on weekends to rip on it and it likely will not see 30k miles over the next 4-5yrs then you are fine. If it's a daily that will see lots of miles (I would want to see the cam card), but I would choose a cam that is .600 lift or less and works with beehive springs. Cam motion would be my choice. 1 7/8 headers are fine...2" will make a little more power but it's not a big deal.
2016 NFG 1SS A8
#5 | |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
I personally wouldn’t buy a cam that they don’t provide a cam card with, YMMV.
#7 | |
23x/24x, .645"/.635", 113 LSA https://www.texas-speed.com/p-7578-t...-camshaft.aspx |
#8 |
If money is no issue - I'd get a quote from Vengeance Racing in Cumming, GA. That shop is considered a national premiere performance shop for the LS/LT GM engine platform. They'll also give you the cam spec card without playing the super secret cam spec game. Or at least they didn't play that game when I had cam work done there on my 5th Gen Camaro. I too would recommend staying away from high lift (above .600) cams for anything but a weekend warrior if driven more than a few thousand miles a year.
Good luck - I do miss my hard-chopping cammed 5th Gen but this 6th Gen is so much better all around.
#9 |
![]() Drives: 2018 1SS 1LE Join Date: Dec 2012
If you are looking for an all out NA build contact GPI
#10 | |
Know anything about the ATI lower pulley being beneficial to the build at all? |
#11 | |
Good luck and I hope you get an awesome and reliable build. I still say give Vengeance a shot at giving you a quote. They are just up the road from ATL and their reputation is hard to beat.
#12 | |
I'll give them a call today and see what they have available, these guys have me out in at the end of november and gave me about a 1 week turn around. I'm basically getting my cam/heads/port kit for about 5.5k with all the additions minus pulley. I just want a nasty chop and powah! ![]() ![]() |
#13 |
I have been looking more at cams, but can't really seem to find one with anything lower than .600 lift. All of TSPs cams are .63X+. I'll go with upgraded lifters and trunnions and new OEM bolts but as far as a lower spec'd cam, I got no info.
#14 | |
![]() Drives: 2012 GMC Sierra, 2018 Camaro SS 1LE Join Date: May 2016
Lift / Lifter / Good Thread
https://cammotion.com/gen-5-lt-camsh...226-238-113-3/ Have a look at the cam above. This is slightly over .600 lift but I believe it is less that the maximum for the Johnson lifters. I would call Johnson to be sure but this is an alternative to the cam / lifter combination and a little milder. If you require a snotty idle, you may also want to speak to Cam Motion about the "chop" factor. Also, have a look through this thread, "Cam upgrade quagmire". I thought there was extremely valuable info in here. Around post #23 they talk about the ls7 lifter vs. the Johnsons. https://www.camaro6.com/forums/showt...ighlight=darth |
Tags |
1le, cam, heads cam, race |
