08-22-2016, 09:39 AM | #15 | |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
tollerable
08-22-2016, 09:53 AM | #16 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
The LT1 is an all aluminum block and heads so the tolerances are slightly looser than a steel block. If you do a lot of downshifting and use the motor to pull your speed down you will blow oil past the rings but your's is excessive. My bet along with others is it was not filled all the way up. I have the 3.6LGX all aluminum and have not used a drop in 4k miles but my 4.6 Northstar is another story.
