04-24-2017, 07:23 PM | #1 |
Drives: 2014 SS Join Date: Dec 2016
kooks headers ground clearance
I'm looking to get a set of Kooks 1 7/8" long tubes for my 2014 SS. I've looked on the internet but can't find any pics showing the ground clearance. Anyone got any pics they could share?
04-24-2017, 08:20 PM | #2 |
Drives: 2010 CGM 2SS/RS M6 Join Date: Jan 2016
I'd be curious to know what stock clearance is, as I didn't think to measure before putting mine on. My car is lowered 1 inch. Cats are the lowest part of the car at 3-5/8 inches and the collectors sit at 3-7/8 inches. You can kinda see in the photo the lowest line of the car. I daily my car and have had no issues yet, but make it a point to avoid speed bumps and such.
Sent from my SM-N920V using Tapatalk
2010 CGM 2SS/RS M6 - Comp 227/243 .620/.612 | Nitrous Outlet Plate Kit - 100 Shot | ARC Bottle Bracket/Heater | NOS Progressive Controller | AEM Wideband | Kooks 2"x3" LTs | 3" Custom Catback | CAI Intake | Bo White PTB | Billet Motor Mounts | Hurst Short Throw | McLeod RXT | RAM TOB | 3.91 W/ Eaton Truetrac, LPW Cover, Poly Bushings, GForce 850HP Axles | Eibach Pro-Plus Kit | Whiteline End Links | Hotchkis Tower Brace | ZL1 Front End | Blue Powder Coated Calipers | Vorsteiner V-FF 101 - 20x11 and 20x10 | M/T Street Comp - 305/35 and 275/40 | 2 JL Amps | Diamond Audio Speakers | JL Stealthbox
04-25-2017, 05:50 AM | #3 |
That doesn't look too bad. Mine is still stock (including ride height)...I'll get some measurements and pics and post em back here
04-25-2017, 07:00 AM | #4 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
I don't have any pictures, but I'm lowered 1 1/4" and have had kooks headers on since 2012, zero issues on normal roads and speed bumps. I wouldn't change them either, loved them since they were installed.
04-25-2017, 07:15 AM | #5 |
WHAT RED LIGHT?!
Drives: 2011 Black Camaro 2SS/RS M6 Join Date: Apr 2011
I don't have Kooks but clearance for me was similar to Samgray20 because I'm dropped 1" also. I can't avoid speed bumps, so I removed the cats and it noticably helped avoid scrapping
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
04-25-2017, 09:44 AM | #6 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Agree with Beefcake. Had them on for over a year (Kooks LTH and HFC's) and lowered the car @ 1"+, and have had no major issues. You certainly do have to be aware when crossing speed bumps, and certain rolling gate tracks, but otherwise, it's not a major issue.
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
04-25-2017, 10:06 AM | #7 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
I have Looks LT cats, plus I am lowered. I hardly ever scrape on anything. Only those crazy large and wide speedbumps. The ground clearence is actually pretty good.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come. |
04-25-2017, 10:30 AM | #8 |
Drives: 2015 2SS/RS/1LE Join Date: Feb 2016
They are tucked. This is my 15 from the bottom for reference.
If you drag your headers you have a lot to worry about other than that.
OEM Z28 CAI, GMPP CNC Ported Heads with BTR 660 Springs, titanium retainers, trunion upgrade. BTR Stage 4 Cam, Kooks 1 7/8 headers with cat delete. NPP exhaust. 509/451 with std correction on Dynojet.
04-25-2017, 05:46 PM | #9 |
that is awesome. Doesn't look like they hang too low. Gonna go ahead and get mine ordered.
