Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 06-30-2015, 02:49 AM   #1
nutbuter
Drives: 2014 ss/rs
offset and tucking tires?
I like the look of the tires to be under the car not sticking past the fender lip. I'd like to run the ever so popular 20x10 and 20x11 275/315 set up but I'm not 100% on the offsets needed to get the look I desire. The m228 wheels have 35 front and 43 rear. Is this the best there is? Or can the rear be tucked a little better with like a 50mm offset?
2014 ss/rs auto hardtop if this matters.
Ps I just joined after creeping for some time now
nutbuter is offline   Reply With Quote
Old 06-30-2015, 11:56 AM   #2
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
Backspacing is typically to get the correct clearance on the inside of the tire, not necessarily to adjust the outside of the tire. Especially when you are trying to squeeze the widest possible tire under the car.
JimE is offline   Reply With Quote
Old 06-30-2015, 04:21 PM   #3
revived
Vrrrm.
revived's Avatar
Drives: 2011 2SS/RS LS3
honestly just go with zl1 or 1le offsets and call it a day, I have seen some members squeeze some huge tires on them and still get a drop to work.
If you going with air bags I would get into the nitty gritty but for a drop just go with zl1 specs or close too those.
revived is offline   Reply With Quote
Old 06-30-2015, 06:10 PM   #4
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
I don't think the +35mm and +43 will stick out at all past the fender.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 07-02-2015, 10:36 AM   #5
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Those offsets and tires will tuck fine. I too hate tires that stick out like the oem ZL1 and 1LE wheels
SUX2BU is offline   Reply With Quote
