Roto-Fab
Old 09-23-2013, 03:04 PM   #1
Cash, Gas & A SS
Drives: ---
Sunroof Replacement Quality
My sunroof has chips on the top surface (seemingly from somebody smacking a beer bottle into it). The dealership can order a new glass pane and install for $1200. They center the pane onto the metal slider by eye. I'm concerned that centering the glass by eye will cause the black edging on the pane to be visible from within the car. Even off from by the slightest fraction will be enough to bother me. Its $400 more the sliding assembly - which to me is worth it if it guarantees a like factory sunroof.
If I order both the glass and the slider, will GM or their supplier send the two pieces already attached?
Cash, Gas & A SS is offline   Reply With Quote
Old 09-23-2013, 04:00 PM   #2
jd10013
Drives: 2012 camaro
you should probably email this question to the service department of the dealership that will be doing the work.
jd10013 is offline   Reply With Quote
Old 09-23-2013, 04:04 PM   #3
dkp2LT
dkp2LT's Avatar
Drives: '11 2SS, '11 C6 GS, '04 MDX
Email Patrick & ask him: patrick@gmpartshouse.com
He's a forum sponsor.
dkp2LT is offline   Reply With Quote
Old 09-23-2013, 05:19 PM   #4
danl
Drives: 2013 JSB Camaro 2ss
man. . . peeps throwing beer bottles and hitting any car is uncool.
Was it at a campus or something? crazy foolz
danl is offline   Reply With Quote
Old 09-23-2013, 05:46 PM   #5
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
$1200 just to replace the glass......Man I would be talking to safelite or some other reputable glass place...............
christianchevell is offline   Reply With Quote
Old 09-23-2013, 06:19 PM   #6
myold88
myold88's Avatar
Drives: SUMMIT WHITE 2SS/RS CAMARO
If I were you I would leave it alone- Your going to cause more problems than you solve. How bad can they be ?
myold88 is offline   Reply With Quote
Old 01-31-2014, 09:07 PM   #7
Cash, Gas & A SS
Drives: ---
Yes it was by a campus. & No, it is not that bad - I can probably play it off as dirt.
I am only 18 so I will not being going through insurance, 1500 is my premium.
Also, I am from a small town in Canada so the only options are dealership or Apple Auto Glass which did such a horrible job (when they replaced a smashed window + windshield) that I will NEVER EVER got there again.
Thank You dkp2LT,
I'll email patrick
Also, do you guys know if the headliner would be put back perfectly if they changed the sunroof?
Old 01-31-2014, 09:19 PM   #8
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
I think the glass comes already framed and bolts to the slider with 4 bolts. No need to remove the headliner. Just get the glass and do it your self.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 01-31-2014, 09:25 PM   #9
Cash, Gas & A SS
Drives: ---
Really? So fitting the glass to the slider should be no problem? I was told 3 hours labour are needed just to pull the headliner back.
dm
Old 01-31-2014, 10:45 PM   #10
layzurguy
Ride On!!!!
layzurguy's Avatar
Drives: 2012 SS Ragtop
Hosers
layzurguy is offline   Reply With Quote
Old 01-31-2014, 10:50 PM   #11
VChula
SoCal C5 Family Member
VChula's Avatar
Drives: 1996 Z28 SS & 2014 ZL1
Don't need to touch the head liner to replace the sun roof glass.
Vance Chula -
1996 Camaro Z28 SS #1688
2014 Camaro ZL1 Coupe #1956
VChula is offline   Reply With Quote
Old 02-01-2014, 10:04 AM   #12
SSMickey
SSMickey's Avatar
dm
And this is just one reason a lot of dealerships have a bad rep. Trying to hose the customer on a customer pay job, or they don't have a clue how to do the job so they figure they'll just charge way more labor than needed to cover the learning curve.
My body shop did the R&R in 30 minutes when they had to pull it for paint touch up.
Old 02-02-2014, 09:16 AM   #13
Cash, Gas & A SS
Drives: ---
Thanks Guys! Is there a way of knowing when the window screws are torqued to 8.5 N m/75lb in?
Old 02-02-2014, 12:03 PM   #14
VChula
VChula's Avatar
Most torque wrenches with a 1/4" drive have lb/in settings.
Here is a link to one:
http://www.harborfreight.com/1-4-qua...ench-2696.html
Vance Chula -
beer, dealership, glass, slider, sunroof
