10-06-2015, 02:51 AM | #1 |
Mixing fuel.
So some of my 4cyl buddies are mixing e85 and 93oct claiming they are running basically 98oct fuel. They have a 93oct tune. Any truth to this or just ricer talk?
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
10-06-2015, 09:23 AM | #2 |
Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
Bad idea unless you built your car to run more than E10 ethanol.
If the cars were tuned to run on 93 octane then running "98" won't help them at all anyway. My motorcycle makes 150HP from a 998cc engine but runs on 87 octane, I won't gain any power by going to 93, in fact I might lose power. Engines run more efficiently using the octane rated fuel they were built to run on, anything more is a waste.
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
10-06-2015, 07:37 PM | #3 |
Drives: 2011 l99 Join Date: Aug 2012
I do it....22 gallons of E85, 58 gallons of 91 oc. in a 80 gallon pickup tank for my Kb 2011 camaro. The car loves it!!!
10-06-2015, 09:33 PM | #4 |
this will only work if you buy the 100hp chip on ebay.
your friends are idiots. dont do it unless your tuned for it and then you would have to mix it consistently. total wast of time and money.
10-07-2015, 03:13 PM | #5 |
Drives: 2012 45th Anniversary Edition Join Date: Aug 2012
If you mix Bacardi 151, and a 190 proof tequila, would you get an drink rated at 341 proof? uh, no.
10-07-2015, 03:22 PM | #6 |
Drives: 2014 Red Hot LS3 Join Date: Oct 2014
10-07-2015, 03:46 PM | #7 |
10-09-2015, 04:25 AM | #8 |
Drives: 2013 Camaro 2SS RS 1LE Join Date: Jun 2013
MMMMmmmm... Tequila!
