Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 09-09-2015, 08:31 PM   #1
HeavyIOM
HeavyIOM's Avatar
Drives: 2010 SS, 2000 Pontiac Formula
Inner tire wear
Ok I have extreme tire wear on the inside of my rear tires on my 2010 SS. The outsides still look good but the insides are bald/ showing wires. Tire pressure is at the recommended level, and alignment is good. What could be causing the extreme tire wear on the inside? Some one told me the camber comes messed up from the factory on the Camaros? I didn't have this issue on my 2012. Tires are RS3s. Anyone have any suggestions?
HeavyIOM is offline   Reply With Quote
Old 09-17-2015, 12:22 PM   #2
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
You say alignment is good, but are you really sure? The other possibility is something is bent but that should show up on an alignment.
I doubt the bushings in the suspension are worn slap out, but you never know. Is the front suspension all stock?
I wouldn't expect a little negative camber to cause any major inside wear issues, nothing that can be adjusted to with stock suspension anyway.
Can you post the spec sheet from your last alignment?
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 09-17-2015, 01:07 PM   #3
Yendor
Yendor's Avatar
Drives: 2017 Camaro 1SS 1LE Hyper Blue
I just swapped my wheels and noticed the same thing. I haven't had an alignment yet but plan to shortly due to my new wheels and tires and not wanting them to wear prematurely.
Yendor is offline   Reply With Quote
Old 09-18-2015, 06:33 PM   #4
Synner
Drives: cars
Your alignment is not good.
Synner is offline   Reply With Quote
