Old 03-12-2018, 02:48 PM   #1
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
Question SOLVED: Part numbers for the correct axle bolts, washers, & retainers???
At the local dealer trying to get the right bolts, but when its looked up on the comp, its showing non-serviceable. So there's no part number for the bolt, retainer, or washers.
Anyone got the iggy on em?
Would loke to get the entire assembly...well 6 of em.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 03-18-2018, 12:53 PM   #2
Drives: 2016 camaro
So time spent at the dealer and some more lookup verification figured it out if it applies to anyone needing new bolts.
Overall bolt length is close to 70mm
But the distance from the retainer to threaded end is around 54mm.
The washer and retainer are about 4mm thick.
When the wife gets back with a watch batt, ill re-add some pics
Old 04-17-2018, 05:35 PM   #3
Mountain
Mountain's Avatar
The part number is 11601876. You’ll need six (6) to cover a car (they are paired bolts with retainers and lock washers).
EDIT: I need to read. You got it.
Old 04-17-2018, 07:38 PM   #4
Drives: 2016 camaro
No prob, def appreciate it
Had em installed a few weeks back. They dont fully engage all the threads, but looking into some ARP bolts that are about 10-12mm longer
