Old 02-28-2018, 11:58 AM   #1
Hyper1SS
Hyper1SS's Avatar
Drives: 2016 Hyper Blue Metallic 1SS M6 NPP
Bleeding Brembo brakes
So I got my calipers powder coated and adding Goodridge stainless steel brake lines. Just wondering like the 5th Gen that had the line at the bottom to connect the two sides when bleeding do you start with the inside or outside bleeder?
2016 Hyper Blue Metallic 1SS M6 with body color hood vents, Silver broken 5 spoke wheels, NPP dual exhaust, Dark Night Interior Spectrum Lighting, Illuminated door sills plates.
Upgrades include: Roto-Fab intake, Mishimoto catch can, MBRP cat-back Race exhaust, TSP 1 7/8 headers, EFI E85 Flex Fuel, MRR M017 graphite wheels with Nitto N555 G2 tires, Goodridge stainless steel brake lines, Powder coated Brembo calipers, BMR suspension, Eibach sport springs, Emblempros fender badges
Order ID: TDHQMS
1100 on 01/07/2016 at Penske Chevrolet
6000 on 02/23/2016 Delivered to customer
Hyper1SS is offline   Reply With Quote
Old 02-28-2018, 02:39 PM   #2
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
I don't think it really matters. I personally did outside first when I did mine, but the calipers should be symmetric, meaning it doesn't matter which side you start on. My only suggestion is after finishing the second side, go back to the side you started on for one of two more open/close cycles. That'll make sure no bubbles crept back in from the other side that wasn't bled first.
In theory, opening both at the same time would work well and eliminate the need to mess with side to side checks, but that might be tricky to pull off.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 02-28-2018, 03:51 PM   #3
Hyper1SS
Hyper1SS's Avatar
Ok. Thank you. I normally make two passes on both sides. I bought this new Harbor Freight one man bleeding system and think I will try it out. Seen a lot of good reviews on it. https://youtu.be/iY52V-qQ-5Q
Order ID: TDHQMS
Old 03-04-2018, 06:42 PM   #4
wrankin
Camaros Of Northwest Ohio
Drives: 2016 Black 2SS
I did the same after getting my rear calipers power coated. It did't work for me so I went back to the old fashion two person method, but used components from the Harbor Freight kit.
Bill
2023 2SS 1LE Red Hot
2016 2SS Black / Black & Arenaline Red (sold)
2023 GMC Canyon Denali
2013 2SS / RS - AGM / Jet Black (sold)
1970 1/2 Z/28 Classic Copper / Tan (sold many years ago)
wrankin is offline   Reply With Quote
Old 03-05-2018, 09:28 AM   #5
TJay74
I have never been able to get those kits to bleed to my satisfaction so I always use the 2 person system.
Old 03-06-2018, 10:44 AM   #6
wrankin
I used the upside-down bottle to keep the reservoir filled, and the other part to collect the flushed fluid - That's about all it was good for, at least for me.
Bill
Old 03-06-2018, 06:07 PM   #7
Hyper1SS
Hyper1SS's Avatar
Great. I will be bleeding the brakes this week. I am going to try it. I heard if you put a little grease on the bleeder screw that helps with air leaks around the fitting when installed.
Order ID: TDHQMS
Old 03-08-2018, 04:22 PM   #8
checkeredflag
TPW 4-11
checkeredflag's Avatar
Drives: 2016 Camaro 2SS Conv. MRC M6 Npp
Just did mine, used a Motive brake bleeder and Castrol SRF fluid. Found some interesting info on the net that said to bleed inner then outer as to not push any inner side debris to the outer. Also start at the wheel farthest away from abs unit which would be driver rear then pass. rear /driver front and last pass. front . That is the way I did it and used 1 liter of fluid for a full flush. Removed res. cap and sucked old fluid out topped off with new hooked up bleeder to the res. applied 14psi and bleed each wheel till I saw new fluid. Must maintain fluid level in res. as to not introduce air. All went well , it was the easiest bleed I ever did.
link to bleeder https://www.amazon.com/Motive-Produc.../dp/B000TK9FE8
Norm
checkeredflag is offline   Reply With Quote
Old 03-12-2018, 05:48 PM   #9
Hyper1SS
Hyper1SS's Avatar
Update. Even though the Harbor Freight kit seemed like a good idea it does not work like it says. I tried 4 times around and still have air in lines. So decided to go back to the old 2 person way. I wish I would have saved my money and got the Motive pressure bleeding kit. Maybe next time.
Order ID: TDHQMS
Old 03-12-2018, 08:29 PM   #10
checkeredflag
TPW 4-11
You might need to cycle the abs unit with a pro type scanner that has the ability for that . Changed calipers one time on a chevy van and it would not bleed properly even with the two person method until I borrowed said tool.
Good luck man.
Norm
Old 03-13-2018, 03:58 PM   #11
Hyper1SS
Hyper1SS's Avatar
Came home and we did it the old fashion way. Nothing can replace the 2 person method. Pedal is just like it should be and no more air in the lines.
Order ID: TDHQMS
Old 03-20-2018, 11:20 PM   #12
Gen5&Beyond
Gen5&Beyond's Avatar
Drives: 2016 2ss Camaro
What brake fluid are you using?
HBM 2016 2SS A8 NPP
427 Pray Head/Cam/Converter, Pray Ported Highram, 103mm TB, Pray Tuned, 3030 Drag Pack, Roark OTR CAI, TSP Headers, E85, UDP
Best times 1/4 n/a 9.23@146.96, 1/8 5.91@118
Gen5&Beyond is offline   Reply With Quote
Old 03-21-2018, 03:47 PM   #13
Hyper1SS
Hyper1SS's Avatar
Motul RBF 600
Order ID: TDHQMS
Old 03-21-2018, 05:16 PM   #14
Hyper1SS
Hyper1SS's Avatar
Good luck man.
I talked to several GM service tech's and you can rent a scanner from AutoZone, buy a scanner from Harbor Freight for $99.00 or activate the ABS system on rocks or grass and it will do the same thing as the scanner. That will allow the ABS system to bleed itself if needed. I have never had to do that on any of my Camaro's after powder coating my Brembo calipers and adding stainless steel brake lines. But I do not empty my entire system so there is always fluid in the brake fluid reservoir.
Order ID: TDHQMS
