Old 08-16-2016, 02:04 PM   #1
Whitemaro6
Whitemaro6's Avatar
Drives: 16 Summit white, Ceramic white 2SS
Cool Weight Reduction Thread.
Hey guys, I wanted to start a Weigh reductions thread. As we start to tear into our cars if anyone comes accross a way to get rid of some weight here and there PLEASE post it here so we can compile the info. Anything from stock wheel weight vrs after market weight. Body pannels, seat changes etc etc... I remeber on my 06 gto you could remove the tow brace and net you 25 pounds right there. Anything like that would be praised i'm sure! THANKS GUYS!
Whitemaro6 is offline   Reply With Quote
Old 08-16-2016, 02:08 PM   #2
sub_ETCS_ret
sub_ETCS_ret's Avatar
Drives: 2019 Dodge Challenger Scat Pack
I'm hoping someone comes up with a replacement back seat. I don't plan on using mine but some type of box or something like an indoor trunk or rear pockets. I owned a 91 CRX and it had something similar. On top it was carpeted and when you opened it there were molded pockets.
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
sub_ETCS_ret is offline   Reply With Quote
Old 08-16-2016, 02:11 PM   #3
HumanWiki
Drives: Car
This is going to be interesting for sure. Even on Gen5 you were pretty much limited to wheels/tires and some exhaust before getting in to some serious $$$$ for weight loss. I mean, you could gut the interior some, but it made the DD aspects kinda crappy with heat/noise and creature comfort.
I know it can be done, but I think it'll hold the same like Gen5. Wheels/Tires will probably be your most cost effective in terms of weight and since it's all rotating, you'll feel/see the best returns. Followed by lighter two-piece rotors.
You might save some on dump the manifolds, but I don't know if it'll offset the headers for $$$ you could just throw in to more power, better traction or handling.
With our redesigned rear 5-link, there may be better options now for tubular or such to drop weight while increasing performance.
EDIT -- almost forgot about warm weather folks being able to swap to a Braille battery for a fairly decent weight loss. No good for those of us in actual winter areas though due too poor CCAs.
HumanWiki is offline   Reply With Quote
Old 08-16-2016, 03:09 PM   #4
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
The only thing I can think of is the drive shaft I saw from the same company that makes the upgraded rear axles. I was thinking about the back seat as well but my little guy would heart broken lol.
You can also go with titanium lug nuts LOL. Those honestly might be one of the dumbest impulse purchases I've ever made. The real deal Ti lug nuts are about $200 for set. They're definitely lighter and much stronger than the fakes on ebay that have aluminum. A lot $ for how much real performance improvement...I have no idea.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
Old 08-16-2016, 06:23 PM   #5
Snowblind
Snowblind's Avatar
http://www.camaro6.com/forums/showthread.php?t=442883
Old 08-18-2016, 07:02 AM   #6
"Charlene"
"Charlene"'s Avatar
Drives: Future V6 Camaro
Just for grins I looked up a good 18" setup from tirerack. Enkei Kojin wheels in 18x8 and 18x9.5 weighing 82lbs between all 4. Then 255/45/18 Conti DW tires for the front and same tire in the back but in a 285/40/18. All 4 tires combined weigh 102.2 according to their website. Which puts the grand total of weight between all 8 = 184.2 lbs. Stock setup is about 249 combined so that's basically a 65lb rotational mass difference which is enormous. Wonder how that would feel compared to a stock wheel/tire setup??
Current:
Cramped POS 2017 Cruze I'm looking to get rid of so I can get into a V6 Camaro.
Previous:
2016 Charger SE
2015 Challenger R/T Scat Pack
2009 Challenger R/T Classic
2009 Challenger SE
"Charlene" is offline   Reply With Quote
Old 08-18-2016, 04:29 PM   #7
Whitemaro6
Whitemaro6's Avatar
Probably night and day. I went to 18lb wheels on my gto and it was amazing. Will def be doing lighter wheels on the camero soon.
Old 08-18-2016, 04:43 PM   #8
SpookShow'84
Bump in the night
SpookShow'84's Avatar
Drives: '84 Monte Carlo SS, '15 Optima
Seems to me there are enough airbags in the car to build a hovercraft. Remove at your own peril though.
SpookShow'84 is offline   Reply With Quote
Old 08-23-2016, 10:09 AM   #9
JaxChris
Be careful, the seat belt nazi's will have a field day with you.
Old 08-23-2016, 05:41 PM   #10
Gone to the bowtie side
Former Ford man
Gone to the bowtie side's Avatar
Drives: 2016 Red Hot 1SS, NPP.
I'm surprised nobody has tried this yet.
2010 Camaro
1100 - 8 Jun 09
reordered with new dealer - 31 Aug 09
2000 - 08 Sep 09
3300 - TPW 28 Sep 09
3400 - 28 Sep 09
3800 - VIN 2G1FT1EW9A9153318
5000 - 21 Oct 09
6000 - 22 Oct 09
traded in for 2016 Camaro
Gone to the bowtie side is offline   Reply With Quote
Old 08-23-2016, 06:03 PM   #11
R3DLT1
Toyota Tech
R3DLT1's Avatar
Drives: 2SS A8
Wnere could someone one buy thise kind of lug nuts......
2016 Camaro SS A8 Roto-Fab CAI: Drag set up 11.9 @116
Sold 95 Camaro Z28 Cam:Bolt ons: 12.3 @114
Sold 2013 Chevy Crzue LTX
R3DLT1 is offline   Reply With Quote
Old 08-30-2016, 07:18 AM   #12
Whitemaro6
Whitemaro6's Avatar
Pulled out all the trunk liner and foam today. Bathroom scale says 10 pounds. Not much but its a start.
Old 09-18-2016, 08:19 PM   #13
jp9109
Clay Sculptor at GM
jp9109's Avatar
Drives: 2016 Camaro 2SS, M6, MRC, NPP
Just did that a few days ago but didn't weigh them. 10 lbs just for those trim pieces seems like a decent amount.
jp9109 is offline   Reply With Quote
Old 10-27-2016, 06:36 AM   #14
Turbo8u
Motorhead
Drives: 2016 Camaro Convertible 2SS
Cars in the stable right now.
2016 Camaro SS Convertible Nighfall
2013 Dodge Charger SRT8
2002 Chevrolet Quad Cab Duramax
2012 Jeep Wrangler Rubicon BUILT, Supercharged
1969 Camaro FAKE Z28
1968 Ford Bronco Rockcrawler
Turbo8u is offline   Reply With Quote
